Re: Scott 100k's recreated [gregclimbs] [ In reply to ]
Greg. What is the drag on the brake levers sticking down like that. I know that the Vision's are pretty narrow but it can not be good having them stick out like that.
Would it be better to have them mounted up higher on the extensions and in like with them so that they are more invisible?
Re: Scott 100k's recreated [jeremyb] [ In reply to ]
In Reply To:
Yep I bought a set too.
Hehehe...I feel like I'm fostering some sort of 100K bar revival ;-)
BTW, for any of you folks wondering how the handling is with them on the bike...I took my TT bike up and down a local twisty 3 mile, 8% grade hill today twice...the second time with a group. I had no problems leading/staying with the group the second time down. For those with motorcycle experience...the key to cornering with those bars is a heavy dose of countersteering :-)
To get a feel for the descent...check out this cool vid of some guys going down the same hill on longboard skateboards:
http://www.youtube.com/watch?v=kkviQ41u0eQ
In Reply To:
I have owned and used both the scott extremes and 100k and the 100k is a MUCH narrower bar...
If the extremes were slow (not surprising, like was mentioned harp, 2x round sections) the 100ks would definately be faster as the narrowness of the bars definately (especially in Tom's position) tend to lead and drag the arms:
http://www.printroom.com/...e_id=262&pos=263
I think this pic captures the narrowness a bit better ;-)
Re: Scott 100k's recreated [Tom A.] [ In reply to ]
Yep great pic.
Want: 58cm Cervelo Soloist. PM me if you have one to sell
Vintage Cervelo: A Resource
Re: Scott 100k's recreated [BMAN] [ In reply to ]
In Reply To:
Those are the same pair that I am giving to Jackmott for the 100k bars that he just bought. Also send him some Jagwire Shifter mounts. I can not wait to see his set up.
The jagwire shifter mounts that you were supposed to send to me????...but didnt????
have you thought of a way to attach a waterbottle or an aerobottle to those?
Dan
http://www.aiatriathlon.com
Re: Scott 100k's recreated [dtreeps] [ In reply to ]
In Reply To:
Nope...then again, I haven't given it any thought.
Re: Scott 100k's recreated [roady] [ In reply to ]
In Reply To:
how long does it take you to do the first 1000 feet of a flat TT with that set-up).
Sounds like a job for the new multi-file range analysis now found in WKO+ 3.0. ;-)
First 329 m after start w/ cowhorns: 32.0 s @ 349 W
First 334 m after turn w/ cowhorns: 33.0 s @ 359 W
First 334 m after start w/ aero-or-die: 31.0 s @ 376 W
First 338 m after turn w/ aero-or-die: 35.0 s @ 334 W
Same Wednesday evening 15 km TT done ~1 y apart...no significant differences in all-up mass, air density, Crr, or gear ratio (53 x 12 fixed gear).
Re: Scott 100k's recreated [IRONwolf] [ In reply to ]
In discussion about them I got the feeling that you did not want them and a straight across trade was fine.
PM if you need to discuss!
are your 100ks faster on the cervelo or the specialised?
I think a good thing to do would be determine a specific brake lever to be used and adapt the bends / cable routing specifically for those brake levers
Post deleted by Administrator [ In reply to ]
Re: Scott 100k's recreated [gabbiev] [ In reply to ]
Some one actually bought the QR CD 0.1 - Cool and I can not wait to see the finished prouduct.
´Get the most aero and light bike you can get. With the aero advantage you can be saving minutes and with the weight advantage you can be saving seconds. In a race against the clock both matter.´
BMANX
Re: Scott 100k's recreated [garageman] [ In reply to ]
In Reply To:
They are faster than my old bars on whatever bike they are on....
bumping an old thread.
did the new design go through? any other suggestions to improve the scott 100k bar?
That is super cool. Very "Kent Bostick".
Tom Demerly
The Tri Shop.com
Did anything ever come of this? I have googled my brains out looking for 100k's the better part of a year
Re: Scott 100k's recreated [tigerpaws] [ In reply to ]
Well, yes and no.
I had these made by a local welder, but never used them. They're sitting in a cabinet in the garage now.
dude that is some SWEET action!
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Michael in Fresno
"Do you spend time with your family? Good. Because a man that doesn't spend time with his family can never be a real man" V. Corleone
jeremyb wrote:
Well, yes and no.
very clever! How wide are the bars at the widest point? I'm not sure if I could go more narrow than the scott 100k's 25cm.
Re: Scott 100k's recreated [Nick_Barkley] [ In reply to ]
http://forum.slowtwitch.com/...string=100k;#3117571
14.5cm outside to outside
Lovely job Jeremy.
As you know, I got as far as the diagram for my S bend 100k repro bars but no further!!
Have you put those bars on the P4 Alu project, or has that creation been sold?
BMANX
Re: Scott 100k's recreated [Barchettaman] [ In reply to ]
Barchettaman wrote:
Lovely job Jeremy.
The bike sold on ebay to a user from Slowtwitch, so it stayed in the "family".
If someone wants to buy those bars off of me, make me an offer --- I've been purging a lot of stuff over the last couple months.
Just in case any of the ST 100K'ers have decided to part ways......look no further than my PM.
I have been digging around my old parts bin for an arm cup solution and found some Scott's and some Mavic's. Anyone else using anything different on theirs that I might be hunting for in the event I ever run across some 100k's to complete the setup? My stockpile is just a bit narrow and not deep enough for my liking.
Thanks
