Travis R wrote:
MaximumTrainer wrote:
Like this? https://www.dropbox.com/...seMovieSize.png?dl=0
You can move the splitter around to increase the size of the media
That's definitely nicer. Could you even take it a step further to allow for the video to be on a separate screen in a dual monitor setup?
It would be possible with the technology used. However as of right now I have other things on the priority list. I suggest using a good video player like VLC and put it on the second monitor, you will loose auto-start/resume functionality with the workout though. If it's really a turn-down to use this solution, I can see to do it later.
fruity wrote:
when I make the graph/ media smaller, and enlarge the space for metrics (i.e. cadence, power ect..) is it possible to actually enlarge the words on the screen. i.e. if I made the whole screen just the power and cadence data, the words/numbers are still so small its hard to read. is there a way to make the words/numbers (especially the small ones like avg power for the interval) bigger?I can add a function to let people control the font manually on each widget, adding to TODO list (see my first post on top for the list)
lightheir wrote:
Any plans for Kickr/CT support in the future? Looks great otherwise!
Thanks!
Free Indoor Cycling Software - https://maximumtrainer.com
