Tom A. wrote:
Why should the manufacturers test more outside?
Those studies (along with logic and physics) demonstrate that drag values obtained within a wind tunnel match extremely close to the data measured outdoors, and to a level well capable of teasing out differences between frames. The correlation is there.
However, wind tunnel testing is significantly faster, easier, and more consistent.
They aren't going to test outside just because you don't get that...that would be a waste of time and resources.
I'm saying that you cannot just choose to focus on the potentially insignificantly small effect of your aero frame, and just use idealized wind tunnel data, and then claim 'my frame is the fastest as per wind tunnel testing', when in outdoor practice, normally encountered variability can render that small measured effect irrelevant and unmeasurable.
It is absolutely NOT a waste of time and resources to test bikes outside the wind tunnel. That's something so easily done as per the article you linked to above, that it SHOULD be done, every time. Costs a HECK of a lot less than a wind tunnel, and is much closer to race situations.
We encounter this sort of 'avoid the-gold-standard test' approach all the time in biology and drug development. Companies might know full well that their drugs don't work as well as they claim in the fuzzier real world situation where real patients take the meds, but they try and pass off selected laboratory highly controlled studies with good results as surrogates measures. If someone is purposefully avoiding providing data that should otherwise easily be measured (and I consider the bikeradar 'experiment' a pretty easy one, at that), you must first ask why they would go through so much trouble to not do the easier outdoor experiment.
If bikeradar did that same trial with 5 bike frames, and couldn't measure a reliable difference, I would conclude 'no significant difference in aero advantages' for those frames, regardless of how well one of the performs in the wind tunnel. Likewise, if they showed that the Cervelo was reliably faster outdoors in those tests, but was last in the wind tunnel, I'd first make sure they weren't screwing up their methodology, but if the methods were sound, I'd go with the Cervelo as fastest.
