Felt IA Build
Starting a IA (FRD or IA1) build. Help me spend my money. Suggestions? Wheels are already decided.
One of the biggest places I am stuck is at front end. Looking at a Enve, TriRig, and Zipp base bars with either a felt stem or TriRig stem.
___________ https://www.instagram.com/toothengineer/ https://www.strava.com/dashboard https://slfmotion.com
2019: IMTX, Rookie, 70.3 Worlds, Lifetime Oly
Re: Felt IA Build [BBLOEHR] [ In reply to ]
I have the Alpha X on my IA, and I love it. If I were buying now, and it were available, I would get the new Alpha. One of the minor details about the basebar I like is that it has a rough grip at the brakes, which means I do not use bar tape. It looks really good. And supposedly, it is one of the most aero.
If the frame comes with an uncut steerer tube, then you can pick your stems at will. If it is cut, then you are pretty much constrained to the Tririg stems (Sigma or Alpha integrated) and the Felt stems. I do not like the base Felt stem, but the Dagger is pretty cool.
What drivetrain are you running? I assume you will go electric, but which flavor (eTap or Di2)? If Di2, hiding the junction box and wires are manageable. If eTap, then you want to think about where you will put the humungous Blip Box. I would consider this in the front end choice as well.
Both of those frame 'modules' come with felt bars already, don't they? Any particular reason you are switching?
Re: Felt IA Build [SBRcanuck] [ In reply to ]
Great point! The IA1 & IA FRD come with the Dagger stem and Devox base bar. It even has the carbon f-bend extensions. You would have to spend a lot of cash to improve on the Devox basebar. On the flip side, you could sell the base bar and do pretty well.
Wouldn't the Tririg bar option be more valid for the IA10 frame set? Together with Tririg brakes you would probably get a more user friendly bike at a lower price.
Ironman 70.3 WC 2019 qualifier
Personal best:
Ironman 9:22:02
Ironman 70.3 4:20:00
Re: Felt IA Build [exxxviii] [ In reply to ]
I don't want to wait for the Alpha One and I technically the Alpha X has less drag. I was going to talk to Felt about the Dagger stem and that is one Josh A. use with his Zipp Bar. What stem are you running now? If I can get the TriRig stem flush it seems like a very good option.
I just picked up a eTap on cyber Monday at 25% off but still am considering Di2 (which i have on my other 2 bikes). Will switch to 165 cranks (Steve Jackson has talked me into this) and prob go with a quarq Dzero.
Larger air foil (which is debatable if it is faster of not) and ability to tilt which is not present on current felt bar.
Re: Felt IA Build [teinvall] [ In reply to ]
I am still considering this option as well. Its def the most cost effective. I do wonder how many grams of drag you give up going this route, seem to have read some places it almost none. I do give up some weight on the frame. One of my goals was to get this bike under 21.5lbs (if possible)
I don't believe you can put a standard stem (zipp, TR) on the IA1 fork. It's an integrated stem design that mates to the base bar.
the world's still turning? >>>>>>> the world's still turning
this IMO is a must for any Felt IA. The bike is just not long and low enough with the OEM +6 stem on there. With the -17 Dagger it gets a little better.
Eric Reid
AeroFit | Instagram Portfolio
Chapel Hill, NC
Aerodynamic Optimized Bike Fitting, Retul Pre-Purchase Bike Fitting, USAT Level 1 Triathlon Coaching, Nutrition
Ask me: Scody Optimized Speed Suits | CeramicSpeed Oversized Pulley Systems | HUUB Skinsuits and Wetsuits | Ventum Bicycles and Frames
Re: Felt IA Build [ericMPro] [ In reply to ]
Those are pro only stems that are not available to the public.
Powered by All Out MultiSport - http://www.aomultisport.com/
Re: Felt IA Build [BryanD] [ In reply to ]
Just bought one from Felt's website. It was a straight swap with the OEM stem... no maintenance or adjustments needed.
Eric Reid
Chapel Hill, NC
I have the Alpha X with its integrated stem on my IA16. That sits pretty flush, but it does not match the integrated shape of the frame-- only the stock stem does that.
You should be able to get a good mount that can cleanly attach the blip box to either the top of the stem (there is a screw hole) or the underside of the BTA plate.
Interesting. I remember Felt saying they made Carfrae a custom stem to use her bars and it wasn't available to the public. Perhaps they listened to people who wanted more options.
You should be able to get under 20 lbs. The IA16 is 20.4 lbs., according to Felt's website. I cut nearly 3 lbs. from my bike just with the carbon wheels, carbon cockpit, crankset, and a few other minor savings. If you are building with high-end going in, you will be well below 20 before adding pedals, PM, and running gear.
That would be fantastic, my current SC is 20.8lbs (no nutrition no water bottles)
Straight up swap, well that seem like the easiest solution then. Can pretty much any any base bar be mounted to the dagger then?
yes, but just to be clear, the dagger stems fit the IA bike with double digits (10/16) and not the IA1 or the FRD. sorry if you already knew this, but you specifically stated the FRD in your original post.
Re: Felt IA Build [Callin'] [ In reply to ]
Good to know! No I am posting all this since I am trying to learn the Felt. Most things on the bike pretty straightforward but the front end is looking like a bit of a challenge.
Question with the Dagger: Josh is on a FRD and has a dagger stem and whats really confusing to me is Felt lists the "dagger stem" coming on the FRD and IA1 Framesets but they don't look right? What am i missing?
Check out pages 31 & 32 in the owners manual: https://www.feltbicycles.com/...IA_Owners_Manual.pdf
The bike looks like it has a normal steerer tube and front end. But, the factory stem and basebar are proprietary and interated. Where it might get off is the look of the front nose cone that covers the brake and how it visually ties into the underside of the stem. It might be fine with another stem, but hard to guess. If you google around, you can find some pictures of alternate stems and bikes with the upper cone removed.
You cannot use a regular stem and bars with the IA1 or FRD. It is a proprietary front end.
Brian Jacobson
Fit2Ride Velo Studio
http://www.fit2ridevelo.com
I'm not sure either to be honest. the FRD comes with a dagger base bar that mates to the integrated dagger stem. The double digit IA models come with a non-integrated dagger stem that would accept anything 31.8. you can see the difference clearer in the international store:
https://www.felt-stuff.com/...athlon-tt/ia-dagger/
As another poster mentioned, the front fork/brake cable cover has two M3 (?) bolts that fix it to holes on either side of the integrated dagger stem.
Looking at pictures of Josh's bike, he seems to have a zipp basebar on there, but also the cover fixed to the font. so he either has the non-integrated dagger with the cover glued/taped on, or the base bar is felt but with zipp painted on (unlikely) or something else.
I'm 99% sure that is not correct. You can run the dagger stem (http://www.feltbicycles.com/...IA-Dagger-Stems.aspx) on an IA FRD and IA1. Look at the holes on the dagger stem where the front brake cover tabs would be. The IA10 or 16 do not have a front brake cover that mates with this dagger stem.
get comfortable being uncomfortable
Re: Felt IA Build [BrianJ] [ In reply to ]
I'm 99% sure this is incorrect. You can use the felt dagger stem... http://www.feltbicycles.com/...IA-Dagger-Stems.aspx
Re: Felt IA Build [stevej] [ In reply to ]
You are correct. I haven't sold Felt for the past year and this is a new stem so you can use non-integrated bar with the IA and still have the brake cover. However, it is only offered in a 110mm -16deg configuration so the aerobar needs to be able to adjust to the riders position. It would be nice if they offered it in a few different lengths.
Brian Jacobson
