stevej wrote:
Callin' wrote:
yes, but just to be clear, the dagger stems fit the IA bike with double digits (10/16) and not the IA1 or the FRD. sorry if you already knew this, but you specifically stated the FRD in your original post.I'm 99% sure that is not correct. You can run the dagger stem (http://www.feltbicycles.com/...IA-Dagger-Stems.aspx) on an IA FRD and IA1. Look at the holes on the dagger stem where the front brake cover tabs would be. The IA10 or 16 do not have a front brake cover that mates with this dagger stem.
wow you are right, I never even noticed the little holes for the brake cover. it's probably what JA is using:
the world's still turning? >>>>>>> the world's still turning
