Michelin suggest pressure between 6 and 8 bars on the road.
6 bars (approx 87 psi) for 50kg rider
8 bars (approx 116 psi) for 80 kg or higher
at 77kg, running my rear wheel on the dry between 110 and 113 is OK for me depending on road quality.
Alu training wheels are comfortable, and do the job.
Racing, generally better road quality, feel OK with carbon race wheels (55mm).
Rec. from Continental for GP4000S2 :
23mm : 110 psi (7,6 bars) - max 120
25mm : 95 psi (6,5 bars) - max 120
I suppose this is for average weight rider : 70kg ?
Considering at 77kg (+10%) I'm in the high range, adding 10% to 95 psi, and running 105 psi (for 25mm rear wheel) make sense for me (Ok I'm slightly above).
Again, when wet, go down to 90/100 PSI (F/R, when both 25mm).
