Pyrenean Wolf wrote:
TriFluid wrote:
What internal rim width? Those psi are...excessvelt high
Hello
Internal rim width : 15 (road aluminum) or 17mm (55mm carbon)
Found these rec. for road 25mm tires :
70 kg : 7,5 bars
80 kg : 8 bars
I'm 77kg, so go for 7,8 bars (113 psi) for rear wheel
Front wheel, remove 10 to 15% if 25mm. If go down to 23mm, in this case same pressure than rear 25mm wheel.
Globally remove 10% or 20% if wet (for grip).
This is coherent with discussions I had with most elite or pro using similar tires (with weigh adaptation, of course). And I'm used to ride on far than perfect road.
I'm heavier than you, usually 80-82kg for races but above 85kg at the moment :(
For my road bike I use 23mm with 85-95psi at the front and 100-105psi at the back without any problems. I often ride on very bad roads and I'm using 15mm internal rims. In summer I switch to 25mm (23mm is needed for clearance from mudguards in winter) and with these I drop to about 75-85psi front and 85-90psi rear on the same rims.
On the tri bike I've got 19mm internal rims and I use 25mm with 70-80psi on the front and 80-90psi rear.
Bad roads make lower pressures desirable IMO, especially on the front when riding a tri bike on the extensions without your arms providing the same shock absorbing duties they do on the road bike. Last time I got a pinch puncture was hitting a raised edge on a drain about 6 years ago so I'm certainly not running too soft for reliability. I do like the front at the mid to upper end of those ranges if I'll be sprinting or climbing on the road bike, just to avoid an excessively squishy feel.
