chrisyu wrote:
Initially, we'll be measuring the electrical power that the drum motors are drawing. That, along with the motor efficiency tables, should get us pretty close. However, if that doesn't look like it's hacking it, we've designed the apparatus so that we can insert some rotary torque cells in the drive system. We'll also have load cells to measure the normal force applied to the tire. As I had mentioned earlier, this measurement will include rolling resistance on our smooth (and small diameter) drum so to tease out rotational aerodynamic drag, we'll need to either use the same tire and pressure and do comparative tests or measure Crr using a lab fixture with a similar drum (and subtract that value out from the total power-to-spin number measured in the tunnel).
Yeah, having the tire Crr in there is a confounder...but, seeing as how the drums would need to be mounted on the balance, you really only need
just enough pressure on the tire to prevent slipping, so that should help minimize any Crr effects. On the front that shouldn't be a huge issue...doing so on the rear, especially if the rear drum is applying a pedaling resistance, might be problematic. I guess that's why Mavic mentioned they'd be building an electric brake into a Comete disc...although I haven't completely thought through exactly how that would work...
chrisyu wrote:
Edit: I just realized you may have also been referring to how we plan on reporting it....well, good question. How would
you like to see it? A total drag curve including everything? 2 separate curves, 1 including all and another including just the translational or rotational drag components?
How about all 3? Translational only, rotational (while subjected to translational air flow), and combined. All in newtons, of course ;-)
