Tom A. wrote:
BTW, and I don't recall if this was brought up earlier, but as you well know, one of the "advantages" of field testing is that the "power to rotate" of the wheels is included in the overall demand.
Chris or Mark, can you go into detail about how you guys plan to measure that value consistently and include it in your measurements?
Initially, we'll be measuring the electrical power that the drum motors are drawing. That, along with the motor efficiency tables, should get us pretty close. However, if that doesn't look like it's hacking it, we've designed the apparatus so that we can insert some rotary torque cells in the drive system. We'll also have load cells to measure the normal force applied to the tire. As I had mentioned earlier, this measurement will include rolling resistance on our smooth (and small diameter) drum so to tease out rotational aerodynamic drag, we'll need to either use the same tire and pressure and do comparative tests or measure Crr using a lab fixture with a similar drum (and subtract that value out from the total power-to-spin number measured in the tunnel).
Edit: I just realized you may have also been referring to how we plan on reporting it....well, good question. How would
you like to see it? A total drag curve including everything? 2 separate curves, 1 including all and another including just the translational or rotational drag components?
And as Robert mentions, the different tools each have different strengths - the tunnel allows us to isolate the effects of different parts of the bike/rider system a bit easier (and going to the extreme, in CFD we can isolate drag contribution from different sub-components). Imagine having different parts (e.g. wheels or mannequin) on an isolated stinger so we still get the aerodynamic flow contribution but we can include or exclude its force contribution. So say we make a change to a wheel and the overall drag reading decreases by X amount. Is that X all from the wheel change or is it now interacting differently with the frame or rider and we're getting some benefit there? (or in an extreme case, maybe the wheel is actually
higher in drag but the frame/rider has benefited enough to compensate).
Sorry I'm rambling now and shouldn't spill all the beans ;-)...
Chris Yu
Applied Technology
Specialized Bicycle Components
@chrisyuinc
