with a pad stack of 605 and pad reach of 440 you are squarely in the center of the range for a 51cm P5d. You'd need the P3x EX10 mono-riser to achieve the 15* of tilt you need.
51cm P5d
mono-riser at 47
pads at +15 setting
For a P3x you are also squarely in size M, mono-riser at 40 and pads at the +30 setting.
What races will you primarily do?
Eric
Pad reach (BOP). 440
Pad width (COP) 170
Tilt. 15 degrees
Seat height. 700
Seat set back. 10
Would like to not be at the end of any range with say 20mm of future adjustment possible.
51cm P5d
mono-riser at 47
pads at +15 setting
Eric
Climb11 wrote:
Pad stack. 605 Pad reach (BOP). 440
Pad width (COP) 170
Tilt. 15 degrees
Seat height. 700
Seat set back. 10
