Notice on the new Dimond
https://51-speedshop.com/...er-aero-bar-system-1
Bar Features
Bar Features
- Nearly invisible to the wind, due to the proven Kamm-Tail airfoil design, and unyielding to even the strongest sprint induced torque.
- Radial shaping of the pursuit bar, combined with a 5 degree up tilt gives the rider greater control over the bike.
- Unique "mono-riser" mounting system allows height adjustment, angulation and stack adjustment through a simple 2 bolt design.
- Three unique extension shapes based on rider preference.
- Carbon reinforced nylon pad holder provides rigidity and support.
- Proprietary arm pad provides the ideal amount of surface area and cushion.
- Debossed channels allow airflow to aid in cooling.
- Arm pad width adjusts from 142mm - 255mm by utilizing one of the two included wing options.
- Arm pad stack up to 60mm and reach by 50mm
- All hardware is corrosion resistant stainless steel.
