I ran the numbers on Sheldon Brown and a 46/11 is the same as a 50/12 and I am just losing a bit for climbing. I am still able to average around 33kph-34kph for my normal 20km TT course. I am missing a bit of top end when zipping down the hills but it just means that I am coasting a bit sooner than normal. The 46 was also a test ring just in case I did not like running 1X so the idea was to test with this and if I did not like it, to move it over to a road 1X set up in which case the 46t would be good matched up with an 11/28 again I don't need more than that for climbing in my area.
Re: Let's see your ride! [BBLOEHR]
BBLOEHR wrote:
Man a 46 is sooooo little!
I think 46 is fantastic! Tried 44/12 as a "big gear". That was too little. But 46/11 is niiiice. And for climbing, 46x28 or 46x32 is actually useful!
But I'm thinking road bike and races with "real" climbing (mile+ at 8% or more). For a flat course, I could get away with 50 or 52 up front, but then I wouldn't need it and would be fine with a 46.
/kj
http://kjmcawesome.tumblr.com/
Re: Let's see your ride! [BMANX]
BMANX wrote:
I ran the numbers on Sheldon Brown and a 46/11 is the same as a 50/12 and I am just losing a bit for climbing. I am still able to average around 33kph-34kph for my normal 20km TT course. I am missing a bit of top end when zipping down the hills but it just means that I am coasting a bit sooner than normal. The 46 was also a test ring just in case I did not like running 1X so the idea was to test with this and if I did not like it, to move it over to a road 1X set up in which case the 46t would be good matched up with an 11/28 again I don't need more than that for climbing in my area.just this morning i was looking at gearing ratios and thinking of moving to a 54/42 trying to gain some more top and for going down hill! I have to run a 11/28 living in austin otherwise i will be walking up hills here, lol.
2024: Bevoman, Galveston, Alcatraz, Marble Falls, Santa Cruz
Re: Let's see your ride! [DuGuy]
"When the going gets weird, the weird turn pro."
Hunter S. Thompson
Re: Let's see your ride! [tri-tele]
Road Bike
Tri Bike(this time drive side)
what gearing are you running?
Re: Let's see your ride! [runitaly]
I was conservative with my first pass and have a 46 tooth up front and 11-36 in the back, but will probably be putting a 48 tooth up front in the next few weeks.
46x11 is still 32.70 mph at 100rpm though......
Hunter S. Thompson
Hunter S. Thompson
Re: Let's see your ride! [N2176T]
Late to the party, but my version of a stealth build.
tri-tele wrote:
I was conservative with my first pass and have a 46 tooth up front and 11-36 in the back, but will probably be putting a 48 tooth up front in the next few weeks. 46x11 is still 32.70 mph at 100rpm though......
I think 46x11-36 is ideal. I currently run 44x11-32 and occasionally want a slightly bigger or slightly smaller gear. Unfortunately I'm limited by my rear derailleur (Ultegra GS) to 32t.
/kj
Re: Let's see your ride! [kjmcawesome]
You should be able to buy a WOLF ROAD LINK. inexpensive and will allow you to run the bigger cassette.
http://www.wolftoothcomponents.com/products/roadlink
tri-tele wrote:
Simple, but very well done, especially the blue accents.
Nice work !
Re: Let's see your ride! [alexer03]
Amaze, love it! Well done
AV8 | Team Wattie Ink Elite 2019
Re: Let's see your ride! [DarkSpeedWorks]
Thanks! Not pictured is my DSW bento bag that goes on for longer events :)
Hunter S. Thompson
Hunter S. Thompson
The bento box comes off for racing. Otherwise, race setup.
I had a 7 min faster HIM bike split (2:20 to 2:13) this past weekend on the same course compared with three years ago on a few less watts (272 vs 278). New bike + race suit and a few other tweaks probably helped to a quicker time.
Coaching: https://bybtricoaching.com/ - accepting athletes for 2023
My 'cheap' aero road bike. Planet-X Stealth TT frame built with drop bars. It is a relaxed TT frame (STA of 76degrees), so worked out nicely and I'm very happy with the ride. I'll throw on clip-on aerobars and bring the seat up and forward for the few aquabikes I do.
Re: Let's see your ride! [natethomas]
Nicely done! Really like this ride. I just ordered the same Dash saddle and hoping its the final winner. And thats some serious 70.3 power
Re: Let's see your ride! [DFW_Tri]
I finally got my ride, even came with Profile Design aero road bars. only one short ride on it so far. Averaged about 15mph for 30 minutes, then one quick sprint and had top speed according to my Garmin of 28.2MPH. Can't wait to really build my base and see what I can do.
Re: Let's see your ride! [cricket1116]
Falco V 1X
My IA10
IA 10
Hed H3 plus front with Conti attack and latex tube
Hed black disc rear with GP4000sII and latex tube
TriRig Omega front brake
ISM PN1.1 saddle
changed the vision crank 52/39 172.5mm to an ultegra 52/36 165mm
x-lab torpedo bta
wahoo elemnt
powertap P1 pedals
I think that's all the upgrades...for now....
[URL=http://smg.photobucket.com/...ds/image_3.jpeg.html][/URL[/url]]
Re: My AR5
Continuing some of the recent Felts...
Felt IA 16 with
Felt IA 16 with
- XLab Torpedo Versa 500 Carbon
- Garmin Edge 520
- Shimano TT78 Brake Levers
- Cee Gees pads
- Cobb 55 Saddle with Cobb rear mount hydration system
- XLab Gear Box Kit
- Powertap P1 pedals
- Tririg Omega X Front & Rear
- Flo Carbon Clincher 60/90
- Continental 4000s II 25 Tires
- Vittoria Latex Tubes
