yep.
I drilled a small hole in the middle of the transition hook.
I have 5 zip ties on the cage. 2 for each of the holes on the cage. Then the 5th on the top flat bit of the cage looped to the hole I drilled on the transition hook. (a bit overkill but secure)
To reduce the chance of ejection even further I have an elastic/hair tie thing cut and tied to the hook and made into a loop that goes onto the mouth of the rear bottle .
you can sort of see it here
I can take close ups later if you want them
