Re: Is there a Felt Mafia? Felt Bike Porn!!! [3Aims] [ In reply to ]
yep.
I drilled a small hole in the middle of the transition hook.
I have 5 zip ties on the cage. 2 for each of the holes on the cage. Then the 5th on the top flat bit of the cage looped to the hole I drilled on the transition hook. (a bit overkill but secure)
To reduce the chance of ejection even further I have an elastic/hair tie thing cut and tied to the hook and made into a loop that goes onto the mouth of the rear bottle .
you can sort of see it here
I can take close ups later if you want them
If you already have a delta mount, you just use this.
http://www.ebay.com/itm/XLAB-Delta-Wing-Adapter-For-ISM-Adamo-Saddles-/190827069625
If you don't have a delta mount, just buy the whole setup.
http://www.ebay.com/itm/X-LAB-Delta-Wing-225-Gorilla-Cage-Rear-Hydration-System-TriathlonTT-NEW-XLab-/271386818783?pt=LH_DefaultDomain_0&hash=item3f2fea38df
I personally already had a delta mount, so I just bought that piece in the first link.
I drilled no holes, not as cost effective as just using zip ties, but there is literally ZERO play in the bottle cage unlike zipties.
Re: Is there a Felt Mafia? Felt Bike Porn!!! [DY3VERSITY] [ In reply to ]
FYI I have minimal play with the zipties.
You just have to tighten them evenly on both sides and pull them tight. Pliers help to tighten them even further
Re: Is there a Felt Mafia? Felt Bike Porn!!! [Mr.Pie] [ In reply to ]
Yea, i understand, but with zipties, you have to replace them once in awhile because they tend to stretch overtime and it really just isn't as solid as the xlab mount. That being said, 1000 pack of zipties is definitely a lot cheaper than the mount. I also did not want to drill into the saddle.
[/url][/image]
Thinking about de-badging my wheels. Thoughts from anyone who has done it?
Re: Is there a Felt Mafia? Felt Bike Porn!!! [GMAN19030] [ In reply to ]
New-to-me 2012 DA frameset with force/red and some even newer-to-me 808s:
______________________________________________________________________________________________________________
"You know me to be a very intelligent man. Don't you think that if I was wrong, I would know it?"
Re: Is there a Felt Mafia? Felt Bike Porn!!! [kronos] [ In reply to ]
Thank you for the proper set up for the cables and handlebar extensions. It makes all the difference in the world in these glamor shots.
-SD
Kronos, Awesome bike and photos!
Re: Is there a Felt Mafia? Felt Bike Porn!!! [bornaero] [ In reply to ]
God the Felt DA frames look so sweet...
Post deleted by Rover43 [ In reply to ]
Re: Is there a Felt Mafia? Felt Bike Porn!!! [liray] [ In reply to ]
Check out my 2014 DA. She is still getting built up for this season. But I am almost there.
Re: Is there a Felt Mafia? Felt Bike Porn!!! [Rover43] [ In reply to ]
Finally got my race wheels in my Felt, very pleased with the result...I know the picture is from the wrong side and it is in the small chainring;)[/img]
Re: Is there a Felt Mafia? Felt Bike Porn!!! [Timmetje] [ In reply to ]
very nice team frame. how much did it cost you?
It was about 1250 euros for the frame, a bargain;) A bike shop in Holland had bought all the bike from the Argos team and was selling them, I was lucky enough to be high on the waiting list
nice nice that is indeed an awesome bargain! enjoy that ride :D
Burning out the groupo before race season on this bad boy. This will be her farewell season before a fall purchase of a 2014 model DA
2009 S32 with Reynolds Strike 66
Prologo EVO Tri40 saddle
X-Labs carbon bottle cage & Rear hydration cages
Garmin 500
105 Aluminium Pedals
Michelin Pro4 Service Course RED
I'll post a photo after race season upgrades: Powertap G3, Ultegra Groupo, Ultegra Carbon Pedals, Cee Gee Pads, Garmin Edge 510, Michelin Pro4 Comp Tyre RED
[url=https://flic.kr/p/mW99Vj][/url]
"Train so you have no regrets @ the finish line"
Re: Is there a Felt Mafia? Felt Bike Porn!!! [cshowe80] [ In reply to ]
My new AR5. Looks even meaner with the carbon race wheels. Got me a 3rd place overall already in a super sprint triathlon.
It begins with the most simple belief, the one you must have in yourself. That must be translated into results by dedication. The knowledge that dedication, which feeds on belief, can make it so.
Hi Rover,
Sorry for correcting you if you are still working on your bike, but your chain seems to be too loose. You might need to remove 1 or 2 links to prevent your derailler from being horizontal.
Good luck!
Tim,
Yea it looks like it is to loose but its just because I put the wheels on and the chain fell off when I took the picture.
Thanks for the heads up,
GD
Re: Is there a Felt Mafia? Felt Bike Porn!!! [LastIntoT1] [ In reply to ]
Do it. Do it now. I debadge everything I can. I'm not getting paid to advertise...you can always justify by the weight it saves, right?
hey guys PSA I just saw over on reddit
Felt recall notice on 2008 and 2010 S-series and B-series TT bikes
http://www.cpsc.gov/en/Recalls/2014/Felt-Bicycles-Recalls-Triathlon-Bicycles/
http://www.feltbicycles.com/USA/Single-Nav/Inside-Felt/Customer-Service/Notices.aspx
Stay safe out there! Check your steerer tube ASAP
Thanks Mr Pie ... I had my warranty work done last season and thank god I saw the recall because mine was in the pool of those affected.
Re: Is there a Felt Mafia? Felt Bike Porn!!! [SuperDave] [ In reply to ]
Dave,
Quick question.....actually a dumb one. I just got a 2013 Felt DA2 with DI2 shifting. Is there a video that shows how to remove the DI battery....I see there is a lever that unlocks it but now sure how to remove it and don't want to screw it up....
Re: Is there a Felt Mafia? Felt Bike Porn!!! [MadisonMan] [ In reply to ]
MadisonMan wrote:
Dave,
Remove:
1-Open the lever
2-push the button
3-pull the battery out
Install:
1-slide battery along guide until it clicks into place
2-close lever
Sub-9 IM. Navy SeaBee deep sea diver. Can Do!
Timmetje wrote:
Finally got my race wheels in my Felt, very pleased with the result...I know the picture is from the wrong side and it is in the small chainring;g]
Very nice rig.......and no one really takes that chain ring thing serious other than the Lance loving ST fanboy mafia!
"I would definitely smell her seat after a century ride"
Rappstar wrote:
That might be the post of the year right there.
