Well crap, I had a nice long post drawn up and hit a wrong key. I just built up 2 of them. A bit of a do as I say not as I do build. A few thoughts....
- We wanted to use our powermeters. Since we don't have a PM sponsor or BBRight PM, we also used the Rotor 46-24 press fit adapter. It was nerve-racking getting it installed. Tolerances are very very tight. ATC said that they have installed the BBRight as well as other press-fit adapters without the super tight tolerances.
- Measure three times, cut once. Especially if your fit is pretty well dialed in. Our bikes were fit so that we were in the middle of the reach column and on the mid/low end of the stack column. If it says you need 3x5mm spacer, you need 1x5mm and 1x10mm. They only send 1x5mm and several 10mm spacers.
- If you are NOT sure of your fit, especially the stack, there are a few things you can do...but Damon and Co. might not approve of the latter one. For both bars, you can use normal spacers under the bar so that you can run a bit more brake line and then cut it 1x when you have the height dialed in. If you run through the aero spacers, you have to cut the end of the line every time you change the height. IF you have a way to adjust the star nut in the fork and you are using the low bar, you 'could' run spacers above the top of the built-in stem as well. If you are using the high bar, you won't be able to do this. BUT, you will have to cut the fork and lower the star nut IF you want to drop the bars because there can't be any fork above the top of the stem to fit the stem cap on the whole assembly. That might not make sense upon reading. The stem/bar combo is structural in that it presses the bearings into the headset.
Having built up a couple, there are a couple of things that would be 'nicer' with the bars, which is a 3T product. The first is to have the compression style bar mounts be a bit shorter in reach. With Amy's bike we had the s-bends cut as short as possible to get the reach to the bar tip correct. Even then, it was almost too long. With ski-bends, no issue. If you want 'tilt' then you may have to sort out a different set of extensions to manipulate your hand height. She is using HED Lazy-S extensions to get a different hand position. The Tri-Rig gamma ones might also give some more adjustability. Just a bit of food for thought. Lastly, a 'slit' in the aero spacers might also be 'cool' so you can remove spacers w/o cutting the cables.
Brandon Marsh - Website | @BrandonMarshTX | RokaSports | 1stEndurance | ATC Bikeshop |
