exxxviii wrote:
Ditto everyone... practice. I have just replaced a lot of tires and flats over the years. It probably takes a dozen or so cycles to get highly proficient.
One big contrast to the above... You will probably not be able to seat the final few inches of a tire bare-handed. If your hands are sweaty during a ride, it is all but impossible. So, just plan to use your tires levers to seat the tire.
Not true. There are two aspects to getting that last bit of the tire onto the rim:
1) ensure that the beads of the tire are in the center of the rim (the smallest circumference available), and
2) generate "slack" in the tire by pulling/pushing the tire, on both sides simultaneously from the part that is seated
to the last part to be seated. Picture holding the wheel vertical with the mounted portion of the tire up and the unmounted
portion on the ground, then work the "slack" into the tire starting at the top and pulling/pushing the tire on each side towards the ground
The second aspect above essentially seats the tire beads as deep in the rim as possible. When the above steps are
taken, the effort required for those last few inches is minimized.
"Go yell at an M&M"
