philly1x wrote:
devashish_paul wrote:
I am looking at the women's lightweight because I probably fall into that "size" range. 6:55 to put it in wattage equivalent is just a touch above 300W...given the largest person in the boat can only be 59 kilos, that's a touch over 5W per kilo...that's insanely high!!!!
6:53 is the WR.
Winter is here
in 19 days. let's not rush it. :)
I have gotten my technique down where I can row consistently at 2 min per 500m with NO STRAPS on....just feet on the platform. When I add the straps, it seems I can row 30-50W harder when I want to push it!
this is good. "feet in" should allow you to throw your core a bit more, so this make sense.
I really enjoy one of the sets where I altenate 10 min of intervals on the computrainer and then 10 min of intervals on the rower, switching between sports and watching the wattage in each sport. Bike seems to be 20-40W higher for the same perceived exertion depending on day.
~66% of the rowing stroke cycle is 0w. but you know this.
it's nice to see you taking to the erg.... and (almost) stealing one for yourself!
Reporting back a year later. I can confirm that my bike watts are now higher at 54 than when they were at 49 even after all my comedy of errors crashes and injuries and rehab. A combo of swim racing for iM and butterfly and constent work on the rowing erg seems to have jacked up my cardio. In fairness I am also around 4-7 lbs heavier than when I was a pure triathlete, but I've almost lost no watts per kilo.
With winter here I really enjoy doing 15 min on the computrainer and 10 min on the Erg and repeat. On the bike I do 5 min easy then 10x54 seconds at 250-300W with 6 seconds at zero watts (so duty cycle is 90%). On the erg, 1000m ease in at 150-180W without straps and then 1000m holding 230-260W strapped in. It depends on how much time I spend hovering between 240W to 260W whether I do that 1000m just above or just below 3:50. And then I go back and repeat the cycle again for a 50 min workout or three times for a 1:20ish workout. Right now I am around 145 lbs. I am finding this to be quite a fun workout and just keeping things on watts makes its interesting going from one torture contraption to the next.
In 43 days I start racing 55-59 so this stupid torture device may indeed be some kind of fountain of youth from a wattage preservation angle, just because you can keep doing a lot of high output cardio really often.
Now if I can just get my running back to some semblance of respectability (I barely broke 50 min in my Olympic tris and did not break 1:50 on the single half IM run, when was biking around 1:06 on slow and windy and turny olympic tri courses and 2:26 in a half IM)...so the engine is doing OK for an older guy. I believe long tern the Concept2 will improve my run due to how well it works my core (psoas, glutes, lumbar)....I would not have been running again without it. I have also noted that I have way more calf and achilles flex than when I started this rehab journey with this machine.
I am also finding that I am cutting some runs short by 10 minutes to put in the final 10 min on the Concept2. I figure at this stage of my rehab, I get better quality training on that (cardio) with low risk of injury compared to more running.
Dev
