tjtryon wrote:
benjaminrpulley wrote:
The only other question I have about the Aero30 is in regards to the little aero sleeve for the straw. I find that after riding over some larger bumps, the aero cover usually gets jostled out of position and will often turn to one side or the other, and not maintain its aero alignment with the rest of the bottle. I am thinking that this might partially be an issue that is related to the splashing because when the bottle splashes, it gets the straw cover pretty wet and this may increase the "slippery-ness" of that connection. Do you have any solution for this? Anybody else out there having this problem? I was thinking I might wait and see if the new 6 cut cover helps decrease the splashing and solve the issue. If that doesn't work though, I might just use a few dabs of superglue at the bottom of the aero straw cover to keep it in place...
Benjamin -
Don't use superglue on the aero sleeve - instead, use some clear silicone. Superglue will corrode the plastic, where silicone is removable when needed. It worked well for me.
The Aero 20 has a new silicone aero mast. Stays on but will still fail if in the unfortunate event of a crash.
Hans Bielat
TorHans LLC Co-Founder, Owner, Chief Innovation Officer
http://www.torhans.com
