RowToTri wrote:
Bonesbrigade wrote:
RowToTri wrote:
In what way does it not line up with your experience?
The calculator has me up around 100psi on conti 23s (yes, I even used 25mm in the calculator), and the ride is quite uncomfortable and a bit jarring that high. My by feel pressure for comfort, cornering, and flat protection is 80-85 psi.
My usual gravel tire setup is 650x42 and he calculator has me in the 25psi range. There would be too much squirm at this pressure and definitely a high risk of flatting. My usual pressure is around 30 -32 psi for my 42mm setup.
Well, Josh is like the world's expert on bike tire pressure and he has tons of real measured data of different tires, wheels road surfaces, riders... I would trust that a lot more than personal feel, assuming you fill it all out correctly. I use gp5000 23c tires but they measure 26mm on my wheels. Hardest thing to know is exactly what he means by "mild asphalt" etc...
If you listen to Joshās podcast, he has detailed how to set your tire pressure by feel for road. He basically says you keeping going lower until you get squirm in the corners or others negative handling trails, and go up a bit from there. I have verified my road pressure with Joshās āby feelā method.
No need to go into detail on the gravel pressure side of things, but if the terrain you ride and the way you ride requires a certain pressure not to flat, and you donāt want to use more volume for various reasons, then you get a pretty damn good feel for off pavement pressure.
Iām sure Josh would agree, the calculator is giving you a good starting place and itās up to the user to adjust up and down from there based on their actual conditions, speed of riding, and riding style.
For me I was just surprised the numbers were quite far from the pressures Iāve concluded to work best for me.
Edit: I forgot to mention, I am a Josh/Silca fanboy š
_______________________________________________
