Ah yeah, I didnโt think about the rim damage aspect.
Re: Silca tire pressure calculator beta [Pyrenean Wolf]
Re: Silca tire pressure calculator beta [Sean H]
Ok, so letโs try and help provide a solution rather than just complain. How would everyone else like for the surface descriptions to progress?
I can only speak to roads, but my experience is this from smoothest to roughest:
Concrete
Smooth new asphalt
Old worn asphalt
Old smoother chipseal
New rough chipseal
Poorly laid chipseal that resembles gravel
Concrete
Smooth new asphalt
Old worn asphalt
New rough chipseal
Re: Silca tire pressure calculator beta [Bonesbrigade]
Alright, sorry for being offline yesterday, we launched this and immediately had problems with the site and once the first people started sharing it, we spent the rest of the day trying to fix it and answer the emails and phone calls.. 4,000 people got the notification, after 1 hour, 15,000 people worldwide were tying to access it.. total cluster, so sorry to everybody who had a poor experience. The goal was to have a more interactive calculator with images and explanations etc, but once it was crashing like crazy we simplified and are now in process of putting it back together.
Answers for some of the questions and an idea of the future plan:
1. Numbers seem weird - Try it today, we had a term in an equation meant to go active in a later version with an additional feature that wasn't zeroed out, so pressures for the first handful of hours were probably trending a bit higher for narrow tires and lower for wider ones.. not by much, but by a few% for sure. This is fixed
2. Surface types - this has been the biggest question and we are working on providing images for each surface as our language is not consistent here. In reality, there are hundreds of options here and we are trying to make a gradient out of them. There is a blog post in the works on this for the official go live of the calculator that will have photos.. also open to ideas on the language as everybody seems to disagree here.
'New Pavement' - think of this as having being paved a few weeks ago using high quality fine aggregate fill, super smooth, low void.
'Mild' pavement as having some visible imperfections, cracks, and undulations, could also be newly paved with large aggregate fill, visible voids.
'old pavement' as being most any road in the midwest, visible cracks, small-medium potholes, occasional damage, 'alligator skinning'
'Cobbles' - Paver bricks to paver stone cobbles, also mild-medium aggregate chip-seal
'Mild Gravel - packed dirt' - This is packed dirt with mild-medium aggregate gravel over top. This is a deformable surface so more efficient to allow the tire to deform more rather than deforming/disrupting the surface. Could also be coarse chip-seal (uncommon)
'Coarse Gravel' - large aggregate or large embedded imperfections like Dirty Kanza flint
3. Measured tire width - This is in fact the measured width of the installed tire at the casing (graphic pulled and coming back soon). It is hard even for me, dealing with this stuff every day, to keep this one straight as we continue to call the tires by their casing numbers, but I have some 23mm GP4000SII on some ENVE with 21.5 inner bead width that measure at 28.9mm wide, so would be 29mm in this calculator. Opposite of that, many of the gravel and mtn tires measure at or below the casing number which seems to be a combination of assuming wide bead seat rims and/or measuring to tread and not casing, for example WTB Riddler 29x2.25 (57mm) actually measure 51mm at the casing (I get 56-57mm at the tread) on the ENVE G23 rim.. so that measured casing number is critical. We also have a piece on this that will make it's way onto the calculator once we are stable.
4. Speed - lastly, we are building in a speed component to further help the discussion and that will also bring a pinch flat risk calculator to the equation. As we often find with the pros, the final pressure is often slightly higher than what you might expect due to the increased energy at which they hit things increasing pinch flat or damage likelihood. Also tire behavior is related to dynamic, rather than just static stiffness, so breakpoint pressure will move higher with higher velocity and lower with lower velocity. As the data in this calculator is almost exclusively taken from ProTour and top level triathlon competitors, the speeds ridden in compiling this data are likely higher than what most of us are riding!
Best and please keep the feedback coming
Thanks
Josh
http://www.SILCA.cc
Thanks
Josh
http://www.SILCA.cc
Re: Silca tire pressure calculator beta [joshatsilca]
Awesome. Thanks for the explanation. In playing around with it a little more I'm starting to see some numbers I more expected to see. In particular at my weight and 26mm, I found the mild vs old pavement numbers interesting and more in line with what I thought: 90psi for mild, 83psi for old. Waco 70.3 last month would have definitely fallen in the old but Indian Wells 70.3 next month will be mild-good.
On a side note, I finally broke down and ordered a Viaggio Travel Pump today. Figured there wasn't much point in knowing the right numbers if I'm not pumping up to the right numbers. No more sharing my pump in transition with the other pros now :P
Benjamin Deal - Professional - Instagram - TriRig - Lodi Cyclery
Deals on Wheels - Results, schedule, videos, sponsors
Gave the pressure calculator a try, but even for mild pavement (with system weight 172lbs), its recommending 93psi for 25mm measured width tires. I'm using Hed jet plus wheels with 23mm gp5000 tires, and Hed says their rims are not rated for above 90psi. Are the hed rims unique in pressure required, or is the recommendation too high? Very cool idea though, thank you for making available!
Re: Silca tire pressure calculator beta [boltz1]
boltz1 wrote:
Gave the pressure calculator a try, but even for mild pavement (with system weight 172lbs), its recommending 93psi for 25mm measured width tires.Are you sure you are measuring 25mm for your tire on a HED wheel? Are you running a tire spec'd as 21mm width? I would imagine that a 23 or 25 spec'd tire would be a good bit wider on a HED wheel.
Thanks much. I have been waiting for this for a while.
One question: Does the tire width and rim width make a difference here? For example, two tires measuring the same may have dramatically different volumes. Take a hypothetical wide tire on a skinny rim that measures 26mm actual versus a narrower tire on a nice, fat, wide modern rim that also meaures 26mm. Should those two tires measuring the same width but with different volumes get different pressures? Do we need a height and width here?
Re: Silca tire pressure calculator beta [iamuwere]
The rim is 25mm outer diameter, and the 23mm tire does not balloon out. I think when I checked it with calipers is was 24. something, its a pretty flush fit with side of rim
If both tires measure the same diameter at the widest point, then the volume of the tire above the rim ought to be nearly identical. But, there could be some difference in total volume, like with HED rims that have a deeper and wider interior channel below the tire.
Re: Silca tire pressure calculator beta [realbdeal]
Wow. I didn't realize this was a thing
I just pump it up to what it says on the side and ride all day [stopping at Wawa every now & then]
"What's your claim?" - Ben Gravy
"Your best work is the work you're excited about" - Rick Rubin
Re: Silca tire pressure calculator beta [RandMart]
You triathletes and your tyre pressures. ๐
boltz1 wrote:
Gave the pressure calculator a try, but even for mild pavement (with system weight 172lbs), its recommending 93psi for 25mm measured width tires. I'm using Hed jet plus wheels with 23mm gp5000 tires, and Hed says their rims are not rated for above 90psi. Are the hed rims unique in pressure required, or is the recommendation too high? Very cool idea though, thank you for making available!That's a suggested max pressure. HED jets are AL rim. You're not going to hurt the rim pumping it up higher than the recommended.
The GP5000's are sized for newer rims. I'd suggest going with 25's on the jet+. The new 25 measures about like the old 23 GP4000.
Heath Dotson
HD Coaching:Website |Twitter: 140 Characters or Less|Facebook:Follow us on Facebook
Josh;
4,000 people got the notification, after 1 hour, 15,000 people worldwide were tying to access it.. total cluster, sorry to everybody who had a poor experience
I guess the good news, is that alot of people are following you and your work !
Thanks for your work.
Re: Silca tire pressure calculator beta [Ex-cyclist]
Thanks for the suggestion. Even with the change to a 25 though, the tire pressure recommendations (per rider weight) on the Hed site recommend me in the mid 70s for tire pressure. Its a pretty big difference
Pressures for my road bike are very close to what I run. A couple pounds higher for the rear and ten pounds higher for the front. I'll try the slightly higher pressures.
For my gravel bike (both 38mm and 47mm tires), the recommended pressures are very low compared to how I race. I suspected they would be, though. I fear the pinch flat and, historically, have kept my gravel tires up around 50 to 55 psi. I'll try slightly lower pressures, but I'm not sure I'll ever get down to 32psi and 24psi. (I'm not saying they aren't the right pressures. I'm just saying I'm probably too chicken to get down to those numbers.)
I think this is a great resource. The problem with it is going to be user error, in that 90% of the people that use it will not actually measure the width of their tire and will go by the printed number on the sidewall. Or if they measure it they're going to hold a tape measure somewhere nearby and eyeball it, and their innate biases will lead them to say it's 23 mm wide when it's really 24 or 25 mm wide.
All of which means that most folks are going to still keep on doing what they do now, which is to pump their tires up too high. Tradition dies hard.
The user needs to be really hit on the head about actually measuring the width. And then hit again. Then you'll start making progress but you still need to hit them over the head again. And again.
Re: Silca tire pressure calculator beta [tttiltheend]
so, is everyone using a micrometer to measure tire width? I didn't realize I needed one in my tool kit. I imagine there is going to be a run on Amazon. Anybody have one they like?
Re: Silca tire pressure calculator beta [Greatzaa]
Greatzaa wrote:
so, is everyone using a micrometer to measure tire width? I didn't realize I needed one in my tool kit. I imagine there is going to be a run on Amazon. Anybody have one they like?Did you not realise. ๐๐
Also a pump to adjust pressure to 0.1psi
And a thermometer to measure the tread temp and internal tyre temp for further adjustments.
If you're not checking and adjusting it every 2km you're so 2010.
๐๐๐
Re: Silca tire pressure calculator beta [Mario S]
๐๐๐
As long as you like to keep unnecessarily wasting watts, I hope youโre in my age group
At the intersection of affordable and decent quality we're recommending these:
Analog Calipers
Digital Calipers
The ones we use in our lab
Everybody should have a set really, you will find all sorts of uses for them and they come in handy for all sorts of things that you probably aren't thinking about yet.
http://www.SILCA.cc
Analog Calipers
Digital Calipers
http://www.SILCA.cc
joshatsilca wrote:
At the intersection of affordable and decent quality we're recommending these: Analog Calipers
Digital Calipers
Oh come on. I gave at least a dozen calipers (as a cardiologist) and I donโt need โcalipersโ to measure a tire. Bend the paper clip so itโs pretty close to the width of the tire and place it against a ruler.
Measured tire width!!
Boom
Re: Silca tire pressure calculator beta [dtoce]
That works too.. but WAY less fun that having calipers ;-)
http://www.SILCA.cc
http://www.SILCA.cc
joshatsilca wrote:
That works too.. but WAY less fun that having calipers ;-)God, don't encourage them Josh!!! :D
I will also add that calipers are the best/easiest way to verify the rule of 105..
A pair will help ensure that you aren't making some simple size and pressure errors with tire choice.
Considering that the penalty of getting these things wrong is probably 3-5x more than you would save by dropping hundreds of $$ on ceramic bearings or the like, the $35 calipers seem like a pretty good value!
J
http://www.SILCA.cc
J
http://www.SILCA.cc
joshatsilca wrote:
I will also add that calipers are the best/easiest way to verify the rule of 105.. A pair will help ensure that you aren't making some simple size and pressure errors with tire choice.
J
Hi Josh, one thing that I note is that the 48/52 weight distribution is probably true for a pro with a slammed set up.... most mortals are not riding that ratio. My simple trial, ie scale under the front wheel zeroed then sit on the bike and see how much of my weight shows up on the front. (the set up was on a trainer and the bike somewhat leveled) said that my normal on the hoods situation was no where near 48/52 but closer to 40/60. I also note that the ratio of air pressure is not a constant depending upon the tire width but that is not a huge thing because most pumps are only good at +/1 psi (that is the minimum reading), but the numbers change with tire width.
So I suggest another addition and that is for riding on the hoods vs drops and most people spend most of their time on the hoods so that changes the front back weight ratio.
ps, BTW I have a couple of pairs of digital calipers and they cost (on sale) less than $20 and I use them a lot. My 25mm Conti 4000IIs are 25.5 and 25.9mm measured at pressure. The fatter tire is on the rear....
