doctorSpoc wrote:
But the vertical force vector has zero effect on the forward motion/energy..
The circumstances in which the horizontal component
exists are relevant. If you're riding steady and straight along a flat road, and the force from the road onto the wheel is only ever pointing perfectly straight up, it means that you're on a perfectly-smooth road surface and you won't ever be bouncing at all.
When you hit a bump, the thing that causes the rearward-oriented force component is the same thing that causes the vertical component of the force to exceed gravity and cause the bike and rider to accelerate upwards. You can isolate them in a force diagram if you want to, but they're not really separate physical phenomena. Again:
visualize the situation in terms of the energy. If you don't think that the energy that bounces the bicycle and rider with overly-stiff tires on rough roads is coming out of the forward motion, where is it coming from?
Quote:
if you rolled over smooth bumps (like a rollercoaster) you would not lose that energy.. would just go between kinetic and potential then returned as kinetic.. like bouncing on a spring.. no loss in energy though.. when you impact a road imperfection.. kinetic energy from you and your bike is lost to the environment though... heat, sound from force of each little impact in the opposite direction of motion...
The rollercoaster example is actually a really good way to visualize what I'm talking about.
If you're rolling up a steep slope, the force from the rails onto the car has a strong horizontal component, and forward motion is being converted to vertical motion very rapidly.
If you're rolling up a shallow slope, the force from the rails onto the car is only weakly horizontal, and forward motion is being converted to vertical motion only very slowly.
The reason that you regain the forward motion lost to vertical motion in the rollercoaster case, but not for the bump in the road, is that the rollercoaster rolls back down a second smooth slope later.
What if the rollercoaster
doesn't do this? Imagine a rollercoaster than rolls up a 1-foot rise, and then simply flies off the rails onto a set of unsloped rails that's one foot lower down. When it lands, obviously there will be a jarring impact, and anyone in the cart will suffer a painful experience. But you won't get any speed back: the energy that was used to go uphill has now been wasted, dissipated through mechanical friction by rattling the cart and the riders' bodies, and in the form of a loud sound as the cart hits the lower rail.
Some friction obviously happens all throughout the process. But friction requires relative movement in order to
happen, and a lot of the energy that gets "lost to heat" is initially converted to vertical deflection of the bicycle and rider. How do you dissipate energy as heat in the rider's body? Shaking the rider up and down is one way to do it! From a raw performance standpoint, the relevant issue is that the energy doesn't have a good way to get converted back into forward motion.
