timbasile wrote:
Runorama wrote:
Gaps are messy. It's about interference drag. As two parallel objects relative to the fluid through which they are moving get closer, overall drag increases above the sum of the individual objects' pressure drag up until the point where both objects start to behave as a single object. In other words, large gaps are fine, small gaps are too, and then there's a sour spot in between.Thanks! That makes sense in my mind. I hadn't considered though that typical aero-bars would fall into the sour spot.
In that case, if I'm running the bars below on a 2021 Speed Concept, tilted at 15 degrees, general aero principles would suggest that I fill in my bars as well?
Or, at least as far high up as I can to still grip the bars. All the better if I can wedge something in (like a piece of foam?) so that the leading edge is shaped more conical? Maybe I can design it with a small pocket so I can call it a gel-holder or something, so its not purely a fairing.
Interesting side bar on that bar
A couple of weeks ago we aero tested a lady that had those bars. She seemed relatively flat and we angled her up about 7 degrees.
She ended up considerably slower. Re-run. Again
So we decided to bring her back down to get back to our A->B->A and the second A was even a bit faster than the original....hmmmmm......
Post ride I checked the accelerometer in the device and sure enough the "2nd" A was a smidge below the first.
So in the end she was maybe 1.5deg, 8.5deg, 0deg and the numbers were better, flatter.
Now we know that tilt is very individual, but it was quite pronounced. Like in 0.015 in her CDA (by memory)
I rarely see such a degradation going from 0ish 8ish degrees.
It was with that bar on a speed concept. I wish I would have spent more time on it.
I can post some of the charts if you're interested.
