jever98 wrote:
I don't ride a Shiv, but since you are at 495 reach, it seems you can go for the L or the XL (there is no stack difference after all), and it depends whether you prefer the shorter stem or longer stem setup. Shorter stem should feel more lively, longer stem more sluggish when cornering. On the other hand the XL will have a longer wheelbase. You would be further back (relatively) on the XL, so would have less pressure on the front wheel.
Thanks for this post. I realize that I am on the cusp and could reasonably choose either side, but what you wrote is very interesting.
On my current setup, I feel my weight it a bit far out over the front wheel, which is something I most notice when cornering; however, I am using a 110mm stem to achieve my position.
On the Shiv, the stem is always 75mm, correct? In other words, for both the L and XL, the bike would probably feel more lively than my current bike. Is that a fair statement?
The setup difference would be that on the L my pads would be farther forward, while on the XL they would be more toward the rear.
Wheelbase on the L is 976 vs 996 on the XL. (For reference, wheelbase on my road bike is 986mm.)
Since stem length doesn't change, does that change your answer?
