Bio_McGeek wrote:
Thanks Maurice, glad you found it helpful. Maybe Dan can make it a sticky.
Ha, I put a LOT of work into waterboy's thread. Saw it as a duty to refute each bit of nonsense and there was a LOT of nonsense. I should probably include that thread as community service for my next job evaluation!
Cheers,
Jim
mauricemaher wrote:
I think this is very much the sticking point. Shortening velocity is usually mentioned on here, but rarely explained.
That was a very concise and descriptive summary for the laymen out here.
Hopefully this directs the conversation away from “you’re an idiot” “no you’re an idiot” that pretty much derails most of the good threads on ST.
On a side note I was I really did like the H2Ofun crank thread....you just had to wade through the mess a bit. There were some really great posts....if you were willing to hold your nose and skip the others.
Cheers,
Maurice
I deal with electrical and mechanical systems at work if you need a larger output or torque then you simply attempt to install something larger.
Having said that we have a very well understood mechanical system (the bicycle drive train) but a metabolic input, this is (variable and unique) READ not a motor with predictable inputs, but also perhaps homogeneous a cross a large spectrum of user groups....world class tters, triathletes, hipsters, and people who have to use bikes to generate the basic needs of life.
Any ways, dan talks a lot about fit etc and puts out some great stuff.
A front pager about shortening velocity and why it may or may not matter to fit would be very interesting.
2c
Maurice
