oscaro wrote:
Yes, we said they are a step above current lc athletes, which is true. Just because Gomez and Alistair haven't done Kona yet, doesn't mean they can't be better athletes than the ones who have.
Really don't see the issue here, and it is quite logical. Just look at the odd 70.3 races they have entered, they crush the entire field and jog it home. Sebi said after St George that he came 2nd in the non-alien division.
Sure, as I mentioned there is a chance that neither of them will do well in Kona, but as we have seen time and time again when athletes move up they succeed more often than not which is true for most sports.
I think what you are missing in this discussion (and your previous post about 10K guys moving up to marathon) is everything from 5K to 10K to half marathon to olympic tri to marathon and even largely half IM racing is largely a fuel depletion event. You basically you go through all the glycogen you have stored on your body, which is roughly 2 hours worth.
When you move up to Ironman that leaves 6 hours that has to come from a combo fat burning or topping up the tank. With the physiology that Brownlee and Gomez have, they should be able to basically swim and ride at a similar percent of their personal FTP to Jan and burn just as much fat as he does. Now the question is how good are they at refueling and who can store more glycogen on their body. It's not a slam dunk what the outcome of this race that requires refueling is to the same extent that a 12.5minute 5000m scales to a 2:03 marathon. Both still are largely a depletion exercise that you can survive through on last night's pasta.
The other factor is Gomez, Browlee, and Frodo all have to devote the exact same percent of their top line wattage to moving 700c wheels through the air at 40 kph-45 kph (or whatever number, assume all these guys are riding the same watts). This leaves Frodo with more of his top line watts to move the bike forward, assuming his slipperiness scales with his size in the same proportion to his top line wattage as the other two guys. Gomez has the biggest disadvantage on this, but Frodo is a bigger guy than Brownlee and for a moment I will assume his brute FTP is larger than Alistair (which may not be a correct assumption, but I'll roll with that for this disussion).
In any case assume three athletes, one 5'10, one 6'1' one 6'4" with the same watts per kilo FTP and relative the same kilos scaling vs height and equally slippery aero for all of them, then the big guy will bike fastest on the flats.....everyone has the same size wheel "tax" at the same speed.
