Gringoloco wrote:
Actually the stem lenght of size S and M is the same - 80 mm. The guy on the video has a size M so that means that an adapter plate would work on all but the XS model.
Did I send you that image via email?
You can see that the clearance on the CF Disc frame with a 110mm stem is less than 20mm. By leaving the tall spacer in he may just have rubber hitting the frame but even that is a risk.
If we create something that has too many caveats it just generates more hassle and risk of harm.
Quote:
Besides, Canyon just launched this model so the frame will most likely be around for at least two more generations.
Frames normally have a 6 year life cycle, other parts may change in that span. PD have a new bottle in the works, I can't speak for Canyon.
Quote:
PD and Canyon have worked together closely for years. How come this is a tough nut to crack?
As I mentioned - we discuss this constantly and have been since early 2019. There are a whole bunch of small factors that add up to make it a more complicated topic than it appears. We may come up with a way to deal with it but currently there isn't a clear path.
