coyote pelon wrote:
i'm with you, latex tubes are fine and maybe have there advantages,
but they drive you crazy with worry -- are they going to blow? leak? sealer work? delicate to mount, higher cost, etc. etc. etc. It's just not worth the worry for 30 seconds of speed. Use something more bomb proof and sleep better the night before the race. ...
Ironically, I've used latex tubes for everyday purposes for so long (without issue), it's actually running butyl tubes that causes me anxiety due to them being more likely to "snake bite" if accidentally hitting an impact edge.
In fact, on the very last set of wheels I put a butyl tube in (a commuter wheelset I don't want to bother pumping every day), I did exactly that on an edge I ride over nearly every day. With wheels with latex tubes in the tires, no problems. First time over with the butyls: snake bite.
Compare that to my road bike wheelset that runs latex tubes. Last weekend I hit a pothole with the rear wheel on a descent hard enough to dent the bead on one side of the rim. No pinch flat though...
