weiwentg wrote:
So, you and lanierb think we need to not push too hard (or at all?) on the valve when seating a pump? How am I supposed not to push on the valve? And these being Vittoria tubes, there are no threads on the valve, so I can't use a valve stem nut.I've destroyed two latex tubes by inadvertently and slightly pushing the valve into the rim. Also Vittoria, so no nut is possible. It can tricky when working in a small opening of a disc valve cut-out.
In the past, there might have been 40, 50 or 60 psi in the tube before I attempted to top it off. With that psi, I was unable to keep the valve from sinking into the hole when I pushed the crack pipe and chuck onto the valve. There was no room to allow my fingers to hold the valve between the crack pipe and rim. The valve would slip down a mm or two without me knowing it. I would inflate and...hisssss.
I no longer have any problem. I now completely deflate the tire/tube whenever I inflate that disc setup. Fully deflating allows me to apply some counter pressure on the tire side of the valve assembly (outside diameter of the wheel/tire) with a finger as I seat the crack pipe and chuck on the valve. That counter pressure ensures I am not pushing the valve down through the hole at all. I make sure to hold the chuck and valve (keeping the valve fully seated) for the first two or three pumps. After that, the air pressure seems to hold the valve against the rim strip during remaining pumps.
