Hanginon wrote:
Tom A. wrote:
Duncan74 wrote:
... However, I did get a 'bad' batch of vittoria tubes in January. All 4 went where the black valve 'skirt' glues to the pink main tube. And all 4 in the same location of that skirt...
Interesting...some of the first Vittoria latex tubes I used a LONG time ago (~10 years ago?) had a similar "batch" failure. Sounds like whatever the fixed in the process back then may have come back to the fore...
I've noticed that the "newer" Vittoria latex tubes have a round skirt on the valve stem - the "older" ones had a larger and more substantial oval skirt. IMHO, the newer ones are not as strong - this one suffered immediate failure in the red circled area.
I'm picking this up because I had a failure in the same region on a recently purchased Vittoria tube. For about a week, my front tube had been losing pressure overnight faster than the rear. It wasn't noticeable while riding, just overnight. Then yesterday, I was pumping up my front tire, and I heard a hiss.
You can't see, but there's a small hole on the left of the stem, and there's a small abrasion that hasn't punctured the tube to the right of the stem. There's also some dimpling of the tube around the stem. There wasn't any debris between the tube and rim strip. I haven't had issues with the rim strip before, and it didn't look like it was damaged. I'll check the other tube, but it hasn't been losing pressure abnormally.
The rim strip is the one Boyd supplies stock with its wheels. I didn't think there should be any issues. However, does anyone know differently? I'm perfectly willing to get some good tubeless tape if it would resolve this.
