I officially had my 3rd spontaneous latex tube failure within the last year. All were on smooth pavement with no punctures and no conditions that would cause a pinch flat. Actually one of them I wasn't even on the bike, it was just sitting in a room after I recently had inflated it. In all 3 scenarios, the tire was inflated to a max pressure of 105 PSI.
One failure was with Flo's recalled rim strips (*edit: before recall had been announced) during my last IM bike leg. One failure was with Stan's yellow tape, the most recent was with ENVE rim strips/tape installed by the LBS last time they trued the wheel.
One of the failures I didn't get to test afterwards, but the last two have been in the exact same place, a lateral leak along the seam where the two halves of the Vittoria latex tube are glued together. In two of the cases, the tire dumped about half of it's pressure and then appeared to hold, but adding additional air caused it to fail completely.
In all cases, I've noticed all my used Vittoria latex tubes begin to develop a 'ripple' along this seam where the failures are occurring, and the specific point of failure (verified under water) is crappily circled below. In all cases the tube visually looks intact, but inflating demonstrates the failure at the seam.
So what the hell is going on? I can't be the only person this is happening to?
