BobAjobb wrote:
Some of what Hambini spouts about that is wrong tho. He quotes tolerances for the bearing installation. But then compares to the housing (= frame hole) tolerances.
He chose to forget the metal bearing 'cup' that the bearing actually fits into - which will 'absorb' a considerable amount of ovality in the frame hole without doing the same distortion to the bearing housing bore.
He's selectively mis-quoting figures.
Don't be so F***ing stupid. You can't absorb ovality. If it's oval then whatever you put into it will either become oval or the strength of whatever you put in it will make the oval into more of a round shape OR more than likely an in between point of the two.
HELLO HAMBINI FANS!!!
