dktxracer wrote:
My wife has the current Domane in SL5 trim. I recently mounted 40 mm gravel tires on it and there was plenty of room for a wider tire, so I did a test fit of the wheels from my gravel bike with 45 mm tires (actual measured width of 44 mm). Those fit fine as well, although a little tight by the chain stays. But I wouldn't hesitate to run 40mm+ tires on the Domane.
Only downside is I think the gearing will be a little tough for climbing for her. 50/34 chain ring against 11-34 cassette. I need to figure out a compatible 46/30 crankset and/or a way to make a MTB cassette with maybe a 40t work. I think the latter would involve changing the rear derailleur.
Bottom Bracket on the current Domane is a T47 which should take just about any road crank, assuming you have the right bearings.
The easy-button options (no need to change anything other than the crank):
-Miche Graff
-Rotor Aldhu 24
Both are available with 46/30 chainrings, and both are build around 24mm spindles. EIther should be a direct swap for any Shimano road crank.
FSA has several crank models which can be had with 46/30 chainrings, but all would require new bearings.
Shimano GRX cranks would fit the existing bearings, but you'd likely have to replace the front derailleur with a GRX fd to accommodate the different chainline. This option would give you more FD clearance for the rear tire, although I'm not sure if that's an issue.
At the other end of the bike, a GRX-812/M-8000SGS Frankenderailleur (M8000SGS cage on the GRX812) should clear an 11-42 cassette without a roadlink, have enough chainwrap to not have to worry about an accidental big/big crosschain, and actually have the proper travel angle to maintain decent b-gaps on the smaller cogs (which is a shortcoming of using a GS road rear derailleur with an 11-40 or 11-42 cassette).
stevie g wrote:
So I think the Giant Revolt offers a good option, takes up to 45 wide tires. Thinking that gravel is not my main thing so go with the Tiagra model.
The question is around the giant semi Hydraulic brake, having run a mechanical disc before, i thought it was flat out dangerous, anyone have any experience of the semi hydraulic, as you have to spend more than a $1000 ore to get full hydraulic?
I think the hybrid Conduct system has been retired for 2021. Haven't seen a bike with the system in their 2021 collection yet. That's good for some models, maybe not so good for others. The 2021 Revolt Advanced 3 now has GRX400 brifters with native hydraulic braking which would almost universally be seen an improvement. The 2021 alloy Revolt has mechanical Tektro 550 calipers, which is probably a step down from the Conduct system that was on the 2020.
