fredly wrote:
Quote:
However, how on Earth do I get the flappy cover for the “storage” fairing behind the seatpost to play nice a sit snug?
Don't install the cover by pushing it straight down into the fairing. There's a subtle taper in the width of the cover from front (of bike) edge to trailing edge. Insert the trailing end of the cover into the fairing about 1/2 way towards the front of the opening, and then slide/push it towards the trailing end of the bike.
That did work, however still pretty slow to open close. Considering 3D printning a plastic cover instead.
The frameset doesn’t Seem to include a dust cover for the top headset bearing, it that a mistake? - or are the spacers/bottom stem plastic cover supposed to function as a dust cover?
A few other notes for anyone building the frameset - di2 grommet for FD doesn’t actually fit in the hole in the frame (hole is round, grommet is oval, had some shimano grommet in the spares box, they work fine.
The Seat stay insert for RD cable didn’t fit in the cutout - cutout too small, had a rubber grommet from a China frame that fit. Storage space door Can’t close properly, because a plastic rivet isn’t pressed in hard enough. Probably just going to sand it Down and add a magnet to keep it shut. In general the assembly instructions are good, however a few things are missing - what are the bolts for, most of them are obvious, But not all, How to actually fit the top tube storage and some on the hex sizes are wrong. Now, I’m going to fit the PD Aeria Ultimate bar and stem (and hydration), But with the included stem and top/bottom cover, it’s more or less impossible to use a torque wrench On the stem bolts - you would need a long one. Most of the bolts are 2,5mm hex and a 2,5mm hex bit isn’t a part of the included torque wrench - wouldn’t have been a problem if the Tool hadn’t been included. But it seems Odd that the size you need the most isn’t there, But something else is.
While the battery Mount in the crank storage is a fantastic idea, it’s seriously fiddly unless you add 5-10cm to the min cable length for di2 (used spares off an old bike, so not a problem, just had to put the b junction near the BB) . Still waiting for parts to come home to do a trainer fit, But in general i’m happy about it. Seatpost on a size large is a bit long, min Seat height at zero offset with ism Adamo saddle is 84cm, which is too much for me (6’ tall). And there’s no torque spec for the Seat rail to Seat post in the manual - tried 5nm, Will have to wait and see if that’s enough. From all if the above, built quality feels like a Chinese open mould frameset, had I payed full retail, I would have been disappointed, But I didn’t pay much more than what an open mould frameset would cost me, so I’m happy about.
And it looks like batman’s bike
