I am wondering if anyone is using a Wahoo Stationary bike as a fit bike?
If yes, how is it working out?
I am planning to buy one. It's not available yet in asia
I've set up a couple of these for clients in their homes and while it could be used for a bike fitting bike, it definitely has its limitations. Any fit bike will be much easier to adjust and you probably won't be able to get a short enough Hx with the wahoo bike for some short riders.
Jonathan Blyer,
ACME Bicycle Co., Brooklyn, NY
What height limit do you think the Wahoo bike will not work at?
I'm thinking of getting one as a fit bike and combining it with BikeFit stem sizer and saddle changer and the Profile design adjustable bars.
If you are looking into this because it’s more affordable than another fit bike then I think you should just look at a used Retul or exit cycling bike.
You will get frustrated and outgrow the wahoo bike in 5 minutes. It doesn’t move nearly as easy as a real fit bike.
Also, check out the acme seat cleat. Way better than that other saddle changer :)
Jonathan Blyer,
