Bonesbrigade wrote:
One thing that isn't clear to me is the clearance of the FD for larger tires. I currently can't fit anything larger than 700x38 on the "old" etap, and I've read they have addressed this with AXS using a slimmer FD design. So, is this a slimmer battery or FD to get more clearance with AXS. Is the AXS battery the same as the old one? I know they are compatible between the old and new etap, based on reading about the battery, but what I can't gleam is if the size and shape of the battery is the same. Got any info on this Dan? thanks!
i believe i have both FDs here, old and new. let me check, and do some measuring.
now, on that subject, part of the problem is frame design. i'm riding exactly what you are: 700x38mm. and on old eTap. my chain stays are 425mm. i don't see eye to eye with every bike maker on this, but, here's my approach to gravel geometry:
1. start with road geometry.
2. figure out every way that a 38mm tire on a 700c wheel impacts something, and normalize for it.
3. ask yourself what you now need to change.
in other words, the larger wheel radius (353mm instead of 336mm or so?) impacts trail. shoe overlap. it raises the bike, so, you've got to correspondingly lower the BB from the wheelbase line from, say, 70mm to 85mm. you add chainstay because the operative metric becomes the leading edge of the inflated tire behind the seat post. you also change the bike's design to account for clearance in the Y and Z axes (front axle to the fork crown, the width of the fork blades, the width of the chain stays.
now, as a frame designer, you ask yourself if all that comports with the use case. no, you might say, you want a higher BB. okay. i don't, but i respect that you might. maybe you don't want road geometry, road contact points. okay. why? let's arm wrestle it out.
the point is, if you did what i suggest you do, as a bike maker, and eTap FD batteries don't hit the leading edge of an inflated road bike tire in 25mm, there's no reason why they should hit a gravel tire.
Dan Empfield
aka Slowman
