LAI wrote:
Toothengineer wrote:
Does anyone know if there is a magic tilt degree number / higher hands? I am maxed at my tilt on a speed concept and was looking for more tilt / higher hands simply to make it easier to hold my head lower. In the velodrome testing I did the higher my hands went the more my CDA dropped, but now this thread is saying that could just be all that the yaw angle is so low at the velodrome.
I started this
thread to see if I could get some discussion going on this exact topic. However, the main individual (desertdude) that suggests high hands isn't all that it's cracked up to be for ~85% of folks didn't respond. I think if all you do is raise your hands it's much less likely to help, but as you are doing it in an effort to improve your position (e.g. head drop, shoulder width, etc.) then I think it's a benefit.
I plan to test changing just hand position in the tunnel this spring to see what it changes in regards to my position and drag.
Its a really great question and I think its a really hard one to answer. You would have to test at diff yaw angles then each race would need to adj based on wind that day. But I do think if getting your hands higher allows you to hold your head tucked in better that must help reduce drag.
For me specifically I cant tuck my head in near as well with a flat bar. I have had limiting factor of the Trek Tilt but with the 51ss extensions I should be able to get them just a touch higher which I was hoping might make the head position even more comfortable.
2024: Bevoman, Galveston, Alcatraz, Marble Falls, Santa Cruz
