BryanD wrote:
TriBriGuy wrote:
"You completely missed the point of the hydration system."
You're going to have to explain how.
It's pretty simple to me. Hydration has to be simple and executable during race conditions. It was clearly not so for the four top pros on that bike on Saturday. Each of them had problems and/or extraneous riggings to deal with its shortcomings.
If the hydration system is not enough to cover the needs of the course, then it should have simple provision to refill, under race conditions duress. I didn't see that, and I saw these pros using other rear hydration that disrupted airflow. I saw Lucy try more than once to close the rubber flap and not get it done.
When I look at this system as it currently stands, and I put it up against my hydration requirements during longer races, it's not a good fit as currently designed.
I'm not saying scrap the whole thing. It just isn't ready for prime time. It needs refinement.
It was never supposed to be refilled. It was only supposed to be a 1 time use in a race. 2 bottles, hidden in a frame, that gets you through at least 2 hours of racing. Add a BTA and a behind the saddle if you want.
You guys keep getting upset because you can't refill it. You make fun of pros who tried to refill it. And yet none of you can wrap your minds around the fact that it's never supposed to be refilled.
How much easier can I make this for you?
The fact that I saw several interviews with athletes talking about how they can fill it on the fly would seem to run counter to the narrative their product people are pushing. I've been part of sponsoring products in the past, albeit tangentially, and product people basically give you a script of the things you are and are not supposed to say about new products. If several athletes are saying you can refill it on the fly, then the product people more than likely gave them that leeway. If they knew it couldn't or shouldn't be refilled, you can be almost certain they told the athletes not to say you could.
