Re: P5 versus the BMC Time Machine [jackmott] [ In reply to ]
You should also note that BMC also has an internal place for the battery (inside the seattube) and is UCI legal.
As far as the brakes, once I had mine set-up they were never touched all season except for adjusting pads between training and race wheels. About a 20 minute process at the most. So I really wouldn't say the brakes are difficult to adjust.
ETA: As far as the aero-ness of the frame, I did not see any difference compared to my Nose-Cone Shiv. Both frames were consistent with speed at a given power. Before I get questioned on my testing protocol, this was based on a season's worth of racing and training on both frames. Both the Shiv and TM01 were roughly the same delta compared to the P3 I had before. So as I brought up when Damon stated the Scott was much faster, the word 'much' is subjective. Is it 20g drag, 50g, 100g? Since this is Cervelo's data we don't know what the gap is, but based on my observations it is right in the mix with the other Superbikes in terms of slippery-ness
Fraser Bicycle | First Endurance
Check out my blog here | Twitter:@tmalis3
Re: P5 versus the BMC Time Machine [sydude] [ In reply to ]
sydude wrote:
Also, another strike against the P5 - if you're in the Di2 camp, because of the P5's hydraulic brakes you can't have the second set of Di2 shifters on the brake levers, just on the bar ends. Takes some of the benefit of Di2 out.
Wrong, and it can be done for about 20-30 bucks.
Quote:
And the BMC is just insanely hot looking. And isn't that really the most important thing?
Yes, it is hot looking. But I'd rather go fast then look good so I can beat people who think this.
Re: P5 versus the BMC Time Machine [oschweidler] [ In reply to ]
oschweidler wrote:
Torn between these two bikes. What's your vote an why?
You are asking a silly question here. :) This is Cervelo sponsored forum here, at least appears so. Anything not Cervelo or Felt sucks here. Silly you for asking that. :) (I am being cynical. Cervelo is also the company that produced P4, that was a huge success for them, that is why they invented P5 for which you have to have a PHD to work on)
Re: P5 versus the BMC Time Machine [atasic] [ In reply to ]
Really not a good idea to make fun of how hard the P5 is to work on (it isn't, at all if you use normal aerobars and brakes) in the context of a thread about the BMC (where rear brake adjustment requires crankset removal)
Better to leave that for shiv tri threads maybe.
Re: P5 versus the BMC Time Machine [Tom Maliszewski] [ In reply to ]
I recently built up my BMC TIme Machine and the brakes aren't that hard to set up. You need to have the correct housing length but other then that it's not bad. I did the whole install and adjustment with the cranks installed and don't see why you would have to remove the cranks to adjust the brakes. I haven't personally owned a Cervelo so can't comment to how hard it is to work on.
Re: P5 versus the BMC Time Machine [James Haycraft] [ In reply to ]
You would rather go fast eh? LMAO This is a hilarious comment to me. How much faster do you really think you are going to go on your P5? You can't tell me how fast because no one knows, unless you've had both bikes setup similar and tested in the same conditions. Then you still probably won't know because the bikes are so close. I'll tell you what's even funnier, how are you going to beat dudes on BMC's just because you are on a P5, give me a break do you think your P5 has a turbo boost button? If you really think it's going to boil down to comparing bikes to whether you beat some or not especially these two bikes, you are smoking crack. Get the bike that looks sick and then beat the dudes on P5's that think they are so fast, now that sounds like more fun.
I think you could probably beat me riding an old Schwinn beach cruiser, but your sense of humor needs some work.
Team OC/AD D
Team Juicy Racing's Skip Barber Racing School and Race Series Forums: http://www.skippyforums.com/
That part of my post was slightly tongue in cheek haha; not meant to be truly literal.
Re: P5 versus the BMC Time Machine [motoxxx] [ In reply to ]
You keep doing what you do; I'll keep doing what I do.
p5 > plasma 3 > BMC
Proven.
Also, you should probably relax. It is an online forum composed mostly of opinion. Train more.
di2 P5 brake handle shifting-from your response you suggest that addition of the brake handle Di2 shifting is possible.could you give details or a reference??In particular I wanted to build another tt bikewith Magura brakes as on the P5 but am reluctant to do this since I find the brake handle DI2 shifting very helpful.I would be grateful for your response
Re: P5 versus the BMC Time Machine [carbonsport] [ In reply to ]
...just add sprint shifters
I would go with the one you think is faster, but I personally would go with the BMC due to quality...handmade in Switzerland!
p5 > plasma 3 > BMC
Proven.
I'm just talking crap, so I am relaxed. This board if full of too many Cervelo boy's running around preaching Cervelo gospel. Train more is definitely key. Cheers
Re: P5 versus the BMC Time Machine [youngrasshopper] [ In reply to ]
BMCs, except for the Impec, are made in Taiwan. Nonetheless, between my wife and I, who each own a Cervelo and a BMC, I would rate BMC's build and finish as excellent and probably superior to Cervelo.
p5 > plasma 3 > BMC
Proven.
What is proven? And where is it proven? Id love to see some numbers!
p5 > p4~ s5 >plasma 3 > BMC
Fixed.
Re: P5 versus the BMC Time Machine [Zoom_zoom_Ben] [ In reply to ]
We have yet to see any aero data for the BMC Time Machine from either BMC or from anyone else. About the best we can do is make some inferences from wind tunnel testing Cervelo did on the P4 and other superbikes and subsequently wrote about here on Slowtwitch. The P4 was slightly faster than the Scott. Cervelo claims the P5 is faster than the P4, so therefore the P5 should be faster than the Scott. Damon Rinard probably based his claim on testing that Cervelo has done in the last year.
Unfortunately, it seems that disclosing wind tunnel testing results, white papers, and the bases for claims of aerodynamic qualities are becoming an increasingly hazardous minefield, because so much depends on the testing conditions and bike setups. Superdave has said there is less and less reason to make such claims, because just about anyone could construct a testing protocol that makes one bike look better than another. Even then, results themselves can be contradictory. If a P4 is faster at low yaw but a Speed Concept is faster at higher yaws, Trek and Cervelo can both claim their bike is faster than the other. White papers and aerodynamic claims need to be carefully evaluated and, even then, you need to decided how the results matter to you. The P4 beat out its competitors most markedly at low yaw angles, but does this matter if you are extremely unlikely to race under such conditions? The P5 is purportedly faster than than the P4, but is this the P5-6 or P5-3? To what degree is this outcome influenced by the Aduro bar? What if the Aura bar, which is less expensive and comes standard on the P5-3, is used instead? What if you put a TriRig Omega brake on the P4? There are a lot of variables to put together in deciding whether the bike, as you would ride it, would be more or less aerodynamic than another.
This says nothing about whether you can actually get the bike and whether you can purchase it from a local shop that has a good fitter, good service, and experience working with triathletes, as well as one with which you also have a good relationship.
Re: P5 versus the BMC Time Machine [kenpetruzzelli] [ In reply to ]
That was my point. To the best of the collective ST knowledge there are no numbers. So the text quoted about it being "Proven" that the P5 is the fastest thing around is patently false.
"White papers and aerodynamic claims need to be carefully evaluated and, even then, you need to decided how the results matter to you."
This. And the more info the claimant is willing to give you to work with, the more informed a decision you can make.
Carl Matson
About this point.
You dont need to take off the crankset to adjust the brake.
1) Take off the rear wheel.
2) Squeeze the rear brakes together.
3) Use a hex wrench with a U-Bend and remove the brake calipers. Swap brake pads or whatever you want to do to the brakes.
Additionally if you want to just adjust the brakes position/distance from the wheels breaking surface there is a little hex nut that squezes the brake-cable.
Losen this nut.
Adjust the brakes distance/position.
Tighhten the hex nut again.
I know a lot of you have trouble fixing a puncture.... but these brakes are not rocket science to work on.
*high five*
Edit: I dont think is has been proven yet which is faster.
I'd expect there is not a massive difference between them, ride which one you like. Be happy if you are lucky enough to own either of them.
No, not "patently false."
http://forum.slowtwitch.com/cgi-bin/gforum.cgi?post=4331694#4331694
damon_rinard wrote:
The Scott is much faster than the BMC....Unfortunately I cannot share the data; perhaps I shouldn't have posted (in order not to tease)....
Just depends on if you believe Damon or not. Objectively, I believe him. Subjectively, I REALLY believe him.
pat·ent·ly (ptnt-l, pt-)adv. In a patent manner; openly, plainly, or clearly:
false (fĂ´ls)
adj. fals·er, fals·est
1. Contrary to fact or truth: false tales of bravery.
2. Deliberately untrue: delivered false testimony under oath.
3. Arising from mistaken ideas: false hopes of writing a successful novel.
4. Intentionally deceptive: a suitcase with a false bottom; false promises.
5. Not keeping faith; treacherous: a false friend. See Synonyms at faithless.
6. Not genuine or real: false teeth; false documents.
7. Erected temporarily, as for support during construction.
8. Resembling but not accurately or properly designated as such: a false thaw in January; the false dawn peculiar to the tropics.
9. Music Of incorrect pitch.
10. Unwise; imprudent: Don't make a false move or I'll shoot.
11. Computer Science Indicating one of two possible values taken by a variable in Boolean logic or a binary device.
Which is incorrect? The "patently" or the "false"? You stated something that is clearly incorrect.
false (fĂ´ls)
Arguing semantics. Nice fallback.
Re: P5 versus the BMC Time Machine [Nick_Barkley] [ In reply to ]
Fixed.
Haha.Uh, huh.
"One Line Robert"
And Damon wouldn't say anything that doesn't scream Cervelo is the fastest true or not would he? Kind of his job ya know.
It's not how you start, it's how you finish
