I use the old ultegra spdr and ...
these give max clearance in the turns, so can keep pedaling - and just skim no problem if you connect
Since the cleat and pedal are so low, I dont have to have my seat very high
They last forever without adjustment ( you can adjust float and release tension).
They are easy to get in or out, even if you get grass on your cleat.
has a clear click and entry so there is no doubt when you are in
The cleat are tiny and have rubber shoes (the small black blocks in the pic) , which give good grip and make it easy to run and walk in them, while protecting the cleat from any wear and keeping them out of the grass
they last forever too just have to tighten the pedal rarely, but never need to replace the cleat and it doesnt start to feel sloppy, always crisp
