lonniecdams wrote:
Okay, alpha one people. There is obviously a great sale going on with tririg right now. I have been going back and forth and back and forth on it. I have a canyon speedmax cf. I need a bit more reach, currently an 80mm stem. My big question is as I get older and less flexible and need to change my position to less aggressive I want to have the ability to adjust my position to the distance or to what my body allows. I am including a pic not the best I was repositioning so I am not completely this far forward on the saddle/pads, but a bit more reach would be nice.
Is the alpha one going to allow me to do this down the road? Also, has anyone cut the steerer tube on the canyon to make the bento box nice and flat. Talk me into this or talk me out of this!
Thanks alpha ones!
I have an Alpha One on my Speedmax CF, you will not regret getting the Alpha One, it's so much better and more adjustable than the stock cockpit. Obviously the height is insanely easy to adjust with one bolt. But, the scoops also add a ton of fore/aft adjustment - I was on the short end of the Bike's reach for my size S Speedmax and the scoops allow me to hit those numbers with ample options to shorten (or lengthen) even more - something the stock cockpit did not allow.
I cut the steerer on my Speedmax; I am running the TriRig Alpha One with 1 10mm spacer and the TorHans Bento X and it aligns pretty well with the bento and all the Di2 wires and brake cables are not almost completely hidden, with the exception the the aerobar shifter cables from the back of the extensions to the stem cover. This set-up does require some modification (drilling new holes) in the Torhans bento, since the Speedmax bento mounts are not standard.
Let me know if you want any more info or want pics of anything.
I am basically replicating the CF that tririg featured sans Delta cover.
https://www.tririg.com/...eedmax_CF_SLX_Review
