Re: TriRig One [Slowman] [ In reply to ]
Oh ok I thought you indicated the One addressed that limitation.
Re: TriRig One [cyclenutnz] [ In reply to ]
cyclenutnz wrote:
Questions for Nick:
- Does the Aerobar Y include a headset cover?
One of the renderings on the TriRig site shows that the stem includes an inset underside to function as a built in headset cover. So my guess would be the y data is based on it sitting down near the toptube w/o an additional headset cover.
Re: TriRig One [kileyay] [ In reply to ]
My primary concern in failure would be not the mast but the two bolt inserts that most of your weight will be on(arduro high V)
Also how are your shifter cables/wires being run from extensions back? I can’t see anything internal.
Maurice
http://www.multisportsolutions.com
“The Alpha X is already a best in class front end, and probably among the fastest. I think I would stick with it for the foreseeable future.“
Thanks for good perspective on the One.
How would you rate the Alpha X relative to Profile Design’s Aeria Ultimate? In other words, which bar do you think is a better choice for those that have settled into a position and are looking for something fast and reliable?
Scot
Re: TriRig One [GreatScott] [ In reply to ]
Scot
i would be intersted in this too. with a qr pr6 disc with an integrated stem, i can't use the alpha x or one, so I'm choosing beteen the pd aeria ultimate and the new morf bars.
2018 Races: IM Santa Rosa, Vineman Monte Rio, Lake Tahoe 70.3
Scot
If you are in the exact position (+/- 2mm) that you need on the Alpha X, I can’t imagine a scenario that the AU is going to be superior aerodynamically.
But because of how weird aero is and how dependent it is on your body and on your body being in the best position, there’s a very real possibility that the superior adjustability of the PD’s AU could trump the aero superiority of TriRig’s AX.
And that’s what Profile Design’s product may be boasting, even as their super adjustable bar solution doesn’t seem like a competitor aerodynamically. Look at the AU next to the 3T Ventus and they just aren’t similar.
But TriRig Alpha X seems pretty similar to the Ventus. Not as similar as the Premier Tactical bar is to the Ventus, but pretty similar.
They’re both good bars. As to what takes precedence — fit or aero — the answer is that they are equivalent and interchangeable and one in the fucking same. Fit is aero and aero is fit.
You’ll never be able to know which product is better for you (I.e. faster for you) without extensive testing. So just choose one in this case.
As we get into this era of peak aero and our equipment is, for all intents and purposes, performance equivalent, I guess we start to focus the conversation on fit and adjustability.
Which is great. Let’s have that talk.
But let’s not lose sight of the goal which is to get from point A to point B as fast as possible — and in specific cases, with enough left in your spine to run very fast for some distance.
Thank you.
While I chew on that, there is also the viability of the AX. As you pointed out earlier, TriRig’s blowout of that bar implies a decision to discontinue the product and (eventually) the related customer support.
All good food for thought over the Thanksgiving Day feast.
Scott
Re: TriRig One [Jim@EROsports] [ In reply to ]
I guess if you go too expensive you move into the territory of super bikes with integrated front ends. In the UK the Trek Speed Concept frameset sells for Ă‚ÂŁ2500 and the new Cube Aerium C68 around Ă‚ÂŁ3500 both of which include integrated front ends (The cube also includes brakes).
If you go for a Cervelo P3 the frameset is Ă‚ÂŁ2299 add in a bar/stem combo if it is much over a grand then it become a bit less of a value way to gain a super bike.
I expect the Alpha X would handily beat the AU in the tunnel for bike only testing. And the Alpha One would be further ahead.
Things change with a rider on though, much smaller gaps and sometimes reversed order.
AU far more adjustable so there is a higher chance of getting into a better position. Sometimes a 'settled position' turns out not to be the last word when gaining adjustability opens more positional options.
Here's an example of a fit I did last week where we switched a P3 from the stock 3T Vola (which are basically as fast as AU bike only). Had previously optimised his fit as much as possible with the Vola so baseline was with AU matched to that position.
Fit performed with Velogic 3D Motion (to track angles and lateral motion) and 3D Aero (dynamic frontal area measurement)
We could have hit the same position by tilting the whole Vola bar up 12 degrees and fitting a longer stem, but that's not really a practical solution. And while it turned out that his existing pad width was best for him - AU gave the possibility to make small changes to test that.
So having a more adjustable aerobar opened up the opportunity for far more significant aero changes than could be achieved by a change in the aerodynamics of the bar itself. And for an Elite - this is a big deal.
Note for Grill: 3D Aero is not intended to give an absolute CdA - it will be in the ballpark but is really intended for measuring changes in FA. His actual CdA would be a little lower than that.
Connect - Velogic Fit l Facebook l Twitter
Or - Speedtheory l Facebook l Twitter
When I look at the pictures on TriRig I am surprised by how much frontal area is a "flat plate". There aren't many shapes that have a higher Cd and the area, especially under the arm pads, looks to have a decent amount of surface area exposed. In the age of marginal gains, this doesn't look good to the eyeball windtunnel. Let's hope this is the prototype.
Re: TriRig One [grumpier.mike] [ In reply to ]
Also the shaders used in rendering can only do some with a black model. I wouldn't assume that what looks flat really is.
Re: TriRig Alpha One [refthimos] [ In reply to ]
I have a TriRig Alpha X with tilt kit and gamma extensions that I'm about to place in the classifieds. If anyone is interested, please PM me.
I switched to the PD Aeria Ultimate. For no reason other than because I wanted to try it. The Alpha X is awesome. Nothing bad to say about it.
2018 Races:
Oceanside 70.3, Oceanside, CA, April 7th | Ironman Texas, The Woodlands, TX, April 28th | Finland 70.3, Lahti, Finland, June 30th | Jonkoping 70.3, Jonkoping, Sweden, July 8th | Waco 70.3, Waco, TX, October 28th
Gear: Dimond Bikes | Desoto Sport | Hoka One One
