DarkSpeedWorks wrote:
Barchettaman wrote:
The problem I had was that, unlike Avid BB5 or BB7, the Spyres mount without conical washers. So if the post mounts are slightly off the caliper is nigh-on impossible to centre over the rotor.
Unless I am missing something, that is amazingly bad.
There is simply no way that most bike frames will have perfect disc brake mounting surfaces (heck, many--maybe most--frames don't even have properly aligned dropouts !) so I can't imagine having disc brakes where you cannot (via conical washers) adjust the caliper position.
I'm not sure conical washers are needed unless something is really off. There is enough of a slot on the caliper itself to adjust the brake to get you close and then the pistons themselves can be adjusted separately to deal with any offset that is left (actually a pretty nice setup). Now, if you have a mounting surface that is not square with the rotor then yeah that's crap, but even with conical washers that's going to be crap to setup.
Like Tom I have Spyres on one of my bikes and find the setup just fine. Also, the brakes work pretty damn good in the dry and wet.
My YouTubes
