I read about clearance issues with a disc cover on the chain stays, but I think they were talking older SC stuff. Do you know if this is accurate on the new models? Thanks for all the help. Its really appreciated.
Re: Official Speed Concept Owners Thread [Carl]
Re: Official Speed Concept Owners Thread [Team_Doc28]
No difference with the new models...interference is dependent on the model and depth of rim as well as your installation technique...I believe most people who dispense with the stock fasteners and tape the cover to the rim have no issues
Carl Matson
Carl Matson
Where does one go about finding the fit calculator that Dan reffered to on his front page article? The one that shows you what stem you would need for differnt frames for your stack and reach.
Thanks!
Thanks!
he linked to it at the very end of the article
Carl Matson
Carl Matson
Carl,
I have a 2013 Speed Concept where I've misplaced the standard rear skewer. Is there a way to get a replacement skewer? Would the local Trek dealer be able to get their hands on one?
Thanks!
"Today is the tomorrow you worried about yesterday."
Thanks!
Re: Official Speed Concept Owners Thread [rss31778]
yup, rear skewer for gen1 SC, cro-mo spindle, W306434
Carl Matson
Carl Matson
Perfect, thank you! Not sure why I feel the need to get one. A bit OCD maybe? Ha!
Hi Carl-
Thanks again for all of your guidance. I have a few additional questions for you:
1. Both my girlfriend and I have 2014 SC's and we both notice a fair amount of "bar buzz" when hitting bumps, or worse, riding rough pavement such as chipseal. We're both running electronic gruppos (she EPS, me Di2) It appears as though the brake housings and/or electronic shifter wires are vibrating in the base bar. Are there any recommendations to reduce/eliminate the noise? I know it's minor but over long rides it can be a distraction.
2. Is there somewhere I can download just the fit spreadsheet that appears in the SC fit guide? (I think you developed it?) I've found it hard to read the #'s as they appear in the guide, and would love to be able to view it separately.
Re: Official Speed Concept Owners Thread [heliskyr]
1) lengthen or shorten the brake housing, put some small zipties on the housing (ala Di2 wires), put a few O-rings on the housing...whatever either puts the housing either in solid contact with the bar walls (i.e. doesn't move) or moves it away from the walls/isolates the housing
2) try this: https://drive.google.com/...QtcDQ&authuser=0
Carl Matson
Carl Matson
Thank you! I'll give those a try
Carl-
My new (used) 2011 SC came with a 60x100 stem, and my old bike had a 45x100. I can't find the 45x100 anywhere and every Trek dealer I call doesn't seem able to order it.
Am I able to achieve the proper fit with the current 60x100 stem based on my Retul numbers below?
Thanks!
Handlebar Stack 569
Handlebar Reach 416
Frame Stack 509
Frame Reach 402
Thanks!
Handlebar Stack 569
Handlebar Reach 416
Frame Stack 509
Frame Reach 402
Re: Official Speed Concept Owners Thread [ACHPier]
no such thing as a 60/100...suspect you mean 60/45?
100/45 is in stock in all domestic warehouses...part # 420565...if you're outside the US I don't know what our offshore warehouse inventory looks like, but that part # can be ordered by any Trek dealer.
bar stack and reach tell me nothing about where your armpads are, so I can't say for sure what effect there might be on your fit. that said:
60/45 and 100/45 have the same stack, so bar stack (and pad stack) won't change between the two stems.
bar reach will be different by roughly 50mm.
unless you had your pads/pad holders near the very back of extensions already on your 100/45 setup, the 60/45 should have no effect on your pad reach (i.e. there's enough adjustability in the pad reach by using different holes on the pad holder, or sliding the extensions forward inside the clamps, or moving your pad holders forward on the extensions, or some combination of the three).
Carl Matson
Carl Matson
Any clearance issues to worry about on 2014 7.5 SC and HED Jet Disc Plus?
None that I'm aware of.
Carl Matson
Carl Matson
Do I need to have a spacer beneath the pad wing on the 2014 model? I just purchased the mounting bracket for a BTA bottle and it doesn't really attach correctly unless that spacer is taken off.
Re: Official Speed Concept Owners Thread [BrentwoodTriGuy]
That spacer exists to give you 5mm increments on pad stack adjust, that's all.
And the mounting bracket should've come with a couple of spacers to lift it over the wing with the wing spacer installed...some people mistake those spacers for packaging details.
Carl Matson
Carl Matson
Hi, how i promised, here´s mi modest 7.0 SC ,so happy with it!
evilactivities: Apr 6, 15 13:50
Re: Official Speed Concept Owners Thread [evilactivities]
Whole lot of looking good going on there. Enjoy!
Carl Matson
Carl Matson
If you don't mind me asking what size frame is that and how tall are you?
Re: Official Speed Concept Owners Thread [zamm0]
zamm0 wrote:
If you don't mind me asking what size frame is that and how tall are you?Its an M frame, with a race lite aerobar (not de bulhorn), and i am 181.5cm and 84.5cm inseam, (long torso short leg type)
Hello Carl,
I recently purchased Speed Concept 9.9 Size Large. The shop ordered the High/Near set up. However, I feel like I'm up higher than I was on my last bike. This is my previous fit report. Would I need to order the Medium/Near to get in a more comparable position? This is my fit report.
Thanks for your help. JD
Re: Official Speed Concept Owners Thread [dake72]
Hi JD
You'll need to upload your fit report to an online picture hosting site and then link to it in your post.
Carl Matson
Carl Matson
Carl,
I had trouble doing that, but here is the info. from my Retul fit.
Saddle Height (BB to center of saddle profile) 806 mm
Saddle Setback (BB horiz to front tip of saddle) -67 mm
Arm Pad Stack BB (BB vertical to top of arm pad) 639 mm
Saddle Angle (angle of saddle to horizon) -3 deg
Eff Seat Tube Angle(BB to center of saddle profile) 76 deg
Grip Angle (grip center to center) - 39 deg
Grip width - 88mm
Frame Stack- 569 mm
From Reach (BB to center of head tube top) 411mm
Handlebar Reach (tip of saddle horrid to bar top) 551mm
Handlebar Drop (den of saddle profile to bar top) -177
Arm Pad Reach (tip of saddle horrid to back of armpad) 489 mm
Arm Pad Drop (cen of saddle to arm pad top) -144mm
Arm Pad Reach BB (BB horiz to back of pad) 423 mm
Grip Reach (tip of saddle horiz to front end of grip) 807 mm
Grip Drop (en of saddle to front end of grip) -85mm
Arm Pad to Grip reach (back of armpad horiz to front end of grip) 318 mm
BB to Grip Reach (BB to front end of grip) 740 mm
Arm Pad Width (armpad center to center) 221 mm
Handlebar Stack 590 mm
Handlebar Reach (BB to center of bar) 484 mm
This was for my Wilier Twin Blade.
JD
Grip width - 88mm
Frame Stack- 569 mm
JD
Thanks JD.
A High-Near on a Large will definitely put you higher than your fit #s indicate. Your pad stack is 639mm...the lowest that stem can go on that size frame is 685mm. Even a Medium-Near bottoms out above your pad stack on the large frame (@660mm).
I get a pad reach of about 465mm (we go to center of pad for our fit chart) from those Retul #s, and based on that plus your pad stack you're much better off with a Low-Near on that size frame. Technically the Medium-Far will get there, but you'd be slammed (no room to drop without changing stems yet again) and you'd need to use part of the pad reach range that really shouldn't be necessary for fit #s like yours.
Carl Matson
Carl Matson
Hi Carl,
Please can you tell me the part number for the little black plastic grommets that come with the bike that are inserted in the threaded holes for the water bottle cages, the draft box and the bento/ speed box on the top tube?
Cheers,
Sean
Cheers,
Sean
