s5100e wrote:
Wow that is very interesting data. So the old belief that chain loss in the whole picture of where your power goes of say 1-2% if off by a bit, for the worst case it is 3.6% and the best case it is 0.8% power loss due to the chain friction. That is eye opening. If I understand correctly then at the pedal you are inputting 150 watts and when the rubber hits the road so to speak there is worst case 241 watts and best case 248 watts actually moving the bike forward. Is that correct?I'm not 100% convinced the figures are true on the real bike. Comparable definitely, but absolute values? Not convinced.
Reading the CeramicSpeed Web site, as U read it the measurement of friction losses are done on a Chain Efficiency Tester (CET) that loads up the chain in equal tension on both halves (top and bottom) running around 2 sprockets (doesn't say what size sprockets). So doesn't represent the real bike situation (other than on a tightly tensioned single speed) where the top of the chain is tensioned by the pedalling power and the bottom only tensioned by the derailleur spring - a tiny fraction of the force in the top part of the chain between chain ring and rear sprocket. Also doesn't reflect the losses from running over the derailleur jockey wheels.
If the installed tension in the CET is high, that will distort the results on an absolute value on-a-bike basis (Try over-tensioning a single speed track bike - and see how much stiffer it is to rotate the cranks !)
