TRIPRO wrote:
Actually it is possible to operate hydraulic hose with a splitter where the reservoir sits in. We dud a built for a customer with 1 functional hand to operate 2 hydraulic disc brakes with 1 lever. But you could also run 2 cables to two separate brakes, but the hardware is quite big and not easy to integrate in a bar or frame. Jeroen
2 brakes from 1 lever is different than 2 levers (and reservoirs) to one brake. In the latter, you'd end up just pushing fluid from one reservoir to the other...
Conversely, hydraulic rim brakes don't require a reservoir and can be set up as a "closed" system. No problem there for 2 levers into one brake...or 2 brakes from one lever, for that matter :-)
