Thanks for mentioning the missing result. There was a bug in some new code when the athlete DNS'd/DNF'd in a particular year, which I've fixed. The sheet has been updated, and you are now #1 in M40-44 :)
I don't have the stats on accuracy, but spot checking, the podium finishers are normally near the top of the sheet. Where it misses is if someone wasn't on one of the participant lists but then ends up on the final start list.
For Ivan, it looks like he has raced as Pro, so when I look at if that name has been in M40-44, or M35-39 the last 5 years, it doesn't return any results. So Pro converting to Age Group is an edge case not covered right now.
Agree that some races are more difficult to place higher in than others and it's something I can look at in the future. For now, the algorithm is the same for all divisions and is meant to be directional (and works because there is normally a wide variety of ability in a race). I recognized that when doing the Psych Sheet for Kona last year (most people having placed in the top 5 to qualify)...I created a different algorithm for that one, but it still wasn't as accurate. Thanks for the feedback!
Toothengineer wrote:
Interesting it did not pull up my 5th place in 2017 at IMTX; so must be slightly off or something not pulling up right? Never to take anything away from way you do this since your the only way that does it... but not all placing are equal. Lets look at IMTX which at least to me always seem to have the most prev KQ'ers racing in it and is harder to place top 5 then other races. This list at certain spots does not seem to past the eyeball test. Ivan Dominguez is the clear cut favorite of m40-44. I would be awesome if you could run back end numbers to see how how the predictions pan out by a % or something. Once again thanks for doing what you do.
