IntenseOne wrote:
The biggest factor in chain friction is dirt...I believe the most obvious, clear choice for a no brainer product is Lilly Lube.
Based on the studies I found and other related comments, I believe that Squirt is faster, even after contaminants are introduced. It is probably at the pointy end where the differences are minor. Lilly Lube is more expensive (at least on Amazon), which is also a detractor. The other wild card that could displace both is Premier's wax-based lube. I do not think it has been compared to Sqirt and Lilly yet. But its 16 oz bottle is a tremendous value.
EnderWiggan wrote:
Is price a factor? ... LG, Castelli and Cuore are at the top from a quality, aerodynamics and price point.
My intent was get the obvious easy recommendations selections. So, some spendy things like Alpha X seems to be so broadly recommended that it is worth it, even though it is expensive. Adding the Aerohead probably did dilute the intent, since it then leads to the high price and low price option. That makes it super complicated. Most would probably argue the Aerohead is better, but it is probably more of a tiny difference and probably not worth 3x the price.
Do you think there is a clear, obvious winner for a tri suit? If the Castelli, LG, Cuore, & Kiwami (also popular on ST) are at parity, and Castelli is the cheapest, then do you think that is the one? I have not really searched for comparative wind tunnel data between those suites. And, I have not researched whether suits are hugely individual, like helmets, when then relegates the choice back to cheapest that is likely to be one of the fastest for most body types.
