Chemist wrote:
lemos wrote:
So, is Caledonia a Road bike with a Gravel bias, and the 3T Exploro a Gravel bike with a Road bias? Am I oversimplifying?
What other contenders would fit this?
There are a number of different bikes that would fit in either, a few off the top of my head...
Road bikes which work fine for a bit of gravel (i.e. can handle tires up to ~35mm wide):
Cervelo Caledonia
Trek Domane
Canyon Endurace
Allied All-Road
Gravel bikes which work well at mimicking a road bike (i.e. similar in weight, aero, geometry/handling):
Cervelo Aspero
3T Exploro
Open UP/UPPER
Domane can fit up to 38s, so that could almost fall in either category. Two other All-road candidates would be the Roubaix, which is is supposed to clear 33s, though the Road.cc review says it is tight. Another is Fuji Gran Fondo that will fit 38s on the stock 19mm internal width rims. I picked up one of the Fuji’s with Ultegra for $1000. It was too good a deal to pass up for a new all carbon bike, but I had to drop to 36s on a 25mm internal width rim (a good example of Why 3t’s WAM is a good idea).
Given the move towards similar geometry between road bike and the racier gravel bikes, maybe the real division between All-road and Gravel should be whether you can swap wheels and get a 650b rim and useable tire in there. A goofier factor would be whether or not they have built in bosses for fender or panniers.
