culpritbicycles wrote:
2 Questions, Sorry to prod as a competitor product.
1. For the attachment bracket. Would you prefer to have something that uses the Px tilt in 5 mm increments. or would you accept something bulkier like my tilt base system that allows infinite adjustment on the go with 1 bolt from -6 to +24 degrees? ( image shown is old version, new has more range)
2. Does the product fit your arm in stock configuration? elbow to fingers? When you are holding the grips. is your full forearm supported or is there a gap?
Thanks for the feedback.
Joshua
1. Personally, I’d prefer to keep the tilt system that the EX10 has. Others may differ, but i know exactly what tilt I need and the EX10 provides it for me. I had issues with old P5x where the tilt would move/slip on big bumps/impacts, and I like the security of the fixed system.
2. Again for me personally, this actually does JUST fit me. My full forearm is supported when I take the pad off the bar; when I put the elbow pad on, it only goes up halfway, and then there’s a slight gap on the forearm. I plan on remedying that with some extra d2zero foam I have sitting around. But I did have to mess around with sizing - I’d originally ordered the medium bars and they didn’t work, so had to reorder these large ones. In other words, having a one size adjusts to all version would help.
___________________________________
MS: Exercise Science
Your speed matters a lot, sometimes you need to be very fast, where sometimes you need to breakdown your speed.
