Murphy'sLaw wrote:
mauricemaher wrote:
Side note,
18.32 pounds when I set up tubeless including lots of stans. With steerer tube high and uncut. Otherwise stock.
Without much thought I think you could get at about 16.5.
Really liking this bike, if I was forced to buy one bike this would probably be it.
Maurice
Which build did you go with??
I've got an ok gravel bike, but - I'm considering an upgrade.
This is now on the short list, along with Exploro and UP (UPPER is just too much cake to justify)
Was thinking of new wheelset for the current steed, but to do that right, it's gonna be like $1.2-$1.5k, and then it's still a heavy, aero brick with nice wheels.
Not my build but it showed up at the shop and I ended up building it, force1x hydro etap, DT Swiss tubeless hoops...basically the high end off the shelf.
If you really wanted to weight weeny this: slam stem, change bar, change crank and saddle, remove down tube bash guard (200gm) etc.
For me though 18 off the shelf with cages and 200 grams of Stan’s is fine.
Aesthetically I don’t like the out swooping gravel bar...what is the advantage? I know it gets you wider and more stable on the downs...I just don’t like the look/style.
Maurice
